Old 04-08-2009, 01:44 PM
robard is on a distinguished road
Alarm 166- Y return margin too small TM-1
Have been having alarm 166 (Y return margin too small) error upon zeroing all axis on startup. I have replaced the mechanical Y axis limit switch to no avail. I checked the switch connections for tightness as well as the servo-motor connectors. I have had this problem before and cleaned the limit switch and it solved the problem but not this time. I also checked the arm that contacts the switch to trigger it and it appeared tight and not bent or damaged. Waiting on my HFO to respond but I though I throw this out on the forum to see if anyone has encountered this problem and found the solution. Thanks in advance.
Robin
Old 04-08-2009, 02:42 PM
Haas_Apps is on a distinguished road
If you have replaced the switch then the grid offset should be reset. The value is in encoder counts and should be between 1/8 to 7/8 of a revolution.
Old 04-08-2009, 02:56 PM
Thanks for the quick response! I do not know anything about the grid offset or how to set this. I suppose this is done through parameters and settings. Would you be so kind as to elaborate on how I do this.
Thanks, Robin A.
Old 04-08-2009, 03:44 PM
This is not really my area of expertise. I would suggest that you call the Haas Factory service department at 805-278-8500 and they should be able to help walk you through it.
Old 04-09-2009, 09:41 AM
Robard,
I have been told by the service engineer that he tried to send you an email and it did not work. Can you please email me and I will forward his email to you.
wreilly@haascnc.com
Old 04-13-2009, 09:54 AM
done, thanks
SL-3H 231 232 alarm on zero return TWyatt9 Mori lathes 3 12-05-2008 02:13 PM
Alarm 167 Zero Ret Margin Too Small lovell110 Haas Mills 11 04-01-2008 12:29 PM
Problem- 1st Prob. on my TM-1: Zero return margin too small! KevinWilkins Haas Mills 20 02-21-2008 08:44 AM
Z return margin error Shotout Haas Mills 3 10-15-2006 10:05 AM
help!! x zero ret margin too small? CNChelp Haas Mills 2 07-13-2006 06:56 PM
