Old 04-06-2009, 11:48 AM
JohnJW is on a distinguished road
Offline Plotting
I was wondering if there are offline Gcode plotters available for Haas controller. I have an older dos based program from a CNC class I took a few years back and Xpert CNC editor that came with VisualMill but none of them works with Haas's M97 local sub routine call nor with macro variables.
Currently I have to load the program into the Haas and plot it on the controller which can be a bit time consuming going though the various local sub routine. Is there a faster way to graphically plot the gcode on or offline? Is there a fast forward button on the Haas controller for plotting?
Thanks,
John
Old 04-06-2009, 04:20 PM
mactec54 is on a distinguished road
Hi JohnJW
The sub that you are using M97 is not for a sub call it should be M98 then this will work
a M97 is for in some controls for tool measurement
Mactec54
Old 04-06-2009, 05:22 PM
Hi Mactec54,
Is it better to use M98 and call an external program? I'll try it and see if the external plotting program will work with it. I kind of like the M97 local call for looping because all the gcodes are contained with one file.
thanks,
John
Old 04-07-2009, 12:52 AM
pit202 is on a distinguished road
I use local call too because I like the programs when they are in one piece.
If you`re searching an offline plotting software try "mach3" this is an pc machine controller but you can use them for checking your codes.
Old 04-07-2009, 10:39 AM
Hi Johnjw
The M97 with your Haas control should work just fine I just read about it in there manual
M97 local sub-program it looks like it could be handy some times for short sub progams It still has to be put together correctly to make it work
I just got used to using M98 sub call so never bothered to look at anything else
Mactec54
Need Help!- Reverse/Back Plotting zachf BobCad-Cam 2 02-19-2009 12:05 PM
Printing/plotting Services? imsofaman Autodesk Software (Autocad, Inventor etc) 0 08-29-2008 08:40 PM
Plotting a sample program. rsm169 NCPlot G-Code editor / backplotter 1 03-16-2008 07:36 PM
plotting troubles? solution here casella Product Announcements & Manufacturer News 0 02-22-2008 04:10 AM
plotting questions HIRAH NCPlot G-Code editor / backplotter 4 10-31-2006 06:30 AM
