Hi, I just finished a little project that I have been working on for a while and thought I would share. ENJOY! This unit was hooked up to my PCOOL nozzle on my HAAS TM-1P which allows for individual programmable height for each tool selected. It allows the user to either select coolant or air via the M08 and M09 commands that are sent to your machine via GCode. I installed a 3 position rocker switch on the HAAS control pendent that allows for the selection of air or coolant. Center postion on the switch is OFF. On the programmable air side of things it allows for manual adjustment at the control box that I mounted to the underside of the HAAS control pendent for the "time between air blasts" and also the "duration in time of the air blast". The impluses sent from the timer unit to to a HIGH FLOW 115 volt air solenoid valve. I did a little test and got approximate 285 pulses like the one shown in the video prior to my compressor clycling. 90to 120 PSI compressor cycle. The installation was done in a manner that resulted in minimal modifications to the HAAS control. I utilized existing mounting holes and grounding lugs that were already in the HAAS control cabinets. The only wire that was modified was the black wire that goes to the coolant pump. Took off the wire connector and replaced it with a butt splicer which is easily reversable. The electronics and techincal knowledge to put this prototype unit together came from my friend Lyle Jagger. Lyle you are the MAN! |
| VERY NICE!!!!!!!! Thanks for that Video and demonstration John
| That is pretty cool, John. Is this something that you plan on selling as a retrofit?
Hi Guys, Thanks for the favorable comments. I haven't given the retail aspect much thought as of this moment. I intend to utilize the beta system for a while and possibily make a few imporvements. I see a lot of posibilities in this system. I have another system that I developed for clamping and unclamping 5C air collet fixtures with dual acting air valves. It can also be utilized for supplying constant air via an MCode. Just amusing myself for the moment. Lyle Jagger is the guy with the idea. I just took the time to put something together in a workable beta test. John |
| problem with programmable coolant function | stovepipesteve | Haas Mills | 14 | 10-14-2009 03:04 PM |
| programmable coolant nozzle | jprobst | Haas Mills | 7 | 06-27-2008 12:38 PM |
| Haas programmable coolant unit problem | xs-speed | Haas Mills | 6 | 01-30-2008 11:54 AM |
| programmable coolant | pit202 | Haas Mills | 8 | 12-21-2006 09:51 AM |
| Questions on Programmable Machines | jynxed | CNCzone Club House | 16 | 12-26-2005 07:27 PM |
