| g code Does haas machines accept g code from an emco machine? I am writing programs on a emco machine I just want to know if haas will accept it |
| Haas machines use standard Fanuc G-code. I can't remember what version it follows. Haas has some specific G & M codes that other machines may not have. I wouldn't try running an Emco program in a Haas. Or if you do want to try it, run the program in siimulato mode to check for alarms and such. |
| thanks I don't know how to run that but it is my friends machine |
| Oh, what is this ! G-code is G-code, couple changes and it will work. |
| yes I am getting a little better on g code. I am able to write the program get the codes in. The only thing is I get some alarms toward the end and need to learn how to fix them better without help |
| i have been programing haas and other machines for a long time. most g code is similar but not the same. this holds especialy true for canned cycles. but with minor changes it should work. also offsets are a touchy issue between machines. so be sure to check the haas and see if it is set to the same cordinate system (although more applicable to the lathes). |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 10:21 PM |
| parametric programming | Karl_T | CamSoft Products | 21 | 05-24-2005 03:58 PM |
| g code interpreters ??? | aran.nav | G-Code Programing | 1 | 01-08-2005 03:31 PM |
| I need sample G code program | bunalmis | G-Code Programing | 1 | 08-24-2004 04:50 AM |
| Getting The Most Out of CNCzone's Posting Features | CNCadmin | CNCzone.com FAQ | 0 | 03-02-2003 12:08 AM |
