Old 03-27-2009, 04:10 PM
lkenney is on a distinguished road
X Axis 165 alarm
Just replaced the x axis motor and cable in my VF-0 1992. had the table run to the right side when we started up figured out that we had disconnected the x axis proximity switch while pulling the x axis cable got that fixed this morning, now it tells me that I have an 165 alarm that says that the x- axis zero switch has been moved which it could well have. How do I correct this alarm?
thank you
Eagle
Old 03-27-2009, 11:17 PM
Selway had me adjust the X axis Grid (parameter 125) so that the home zero is at a known location and away from the x axis switch a little. We be working now. Distance to go on the position screen is 1180 for X
Eagle
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
c-axis alarm BAD DOG Daewoo/Doosan 5 06-16-2008 02:36 PM
I keep getting a c-axis alarm APP Haas Lathes 4 04-15-2008 01:01 PM
y axis disconnect alarm kirby Fanuc 8 03-14-2008 04:27 PM
4th axis alarm johnmckeown Haas Mills 2 04-13-2007 05:54 AM
