Results 1 to 9 of 9
Thread: Subprogram Problems
    Sep 2007
    Subprogram Problems
    I'm having a few problems with my posted subprograms code.
    It will run the P1 but when it gets to P2 the error says that the subprogram is not in memory. I'm using an Ethernet connection if that makes any difference? 2002 VF-1
    Code below, thanks
    O0
    (PROGRAM NAME - T )
    (DATE=DD-MM-YY - 20-03-09 TIME=HH:MM - 11:44 )
    G21
    G0 G17 G40 G80 G90
    ( 3MM END TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - 3. )
    T2 M6
    G0 G90 G56 X-25. Y26.5 S9900 M3
    G43 H2 Z10.
    M98 P1
    G90 G58 X-25. Y26.5 Z10.
    M98 P1
    M5
    G91 G28 Z0.
    G28 Y0.
    M01
    ( 4MM END TOOL - 3 DIA. OFF. - 3 LEN. - 3 DIA. - 4. )
    T3 M6
    G0 G90 G56 X14.927 Y0. S9900 M3
    G43 H3 Z10.
    M98 P2
    G90 G58 X14.927 Y0. Z10.
    M98 P2
    M5
    G91 G28 Z0.
    G28 Y0.
    M30
    1
    Z5.
    G1 Z0. F300.
    X25. F1200.
    G2 X26.5 Y25. I0. J-1.5
    G1 Y-25.
    G2 X25. Y-26.5 I-1.5 J0.
    G1 X-25.
    G2 X-26.5 Y-25. I0. J1.5
    G1 Y25.
    G2 X-25. Y26.5 I1.5 J0.
    G0 Z10.
    M99
    2
    Z5.
    G1 Z-1. F300.
    G3 X0. Y14.927 I-14.927 J0. F600.
    X-14.927 Y0. I0. J-14.927
    X0. Y-14.927 I14.927 J0.
    X14.927 Y0. I0. J14.927
    G0 Z10.
    M99
    Jul 2005
    Looking at your code I cannot understand why it runs P1 because you are using M98 P1 which is a call to a completely separate program.
    If you change the M98 to M97 that program should run.
    Question: Do you have a program named O00001 in memory?
    Registered dcoupar's Avatar
    Mar 2003
    Your subs are labeled 1 and 2. They should be O1 and O2 (separate programs) if you're going to use M98, and N1 and N2 if you're going to use M97.
    May 2008
    Quote Originally Posted by frogger View Post
    Code below, thanks
    O0
    (PROGRAM NAME - T )
    G21
    G0 G17 G40 G80 G90
    T2 M6
    G43 H2 Z10.
    M97 P1002
    //G90 G58 X-25. Y26.5 Z10.
    //M97 P1002
    M5
    G91 G28 Z0.
    G28 Y0.
    M01
    T3 M6
    G43 H3 Z10.
    M97 P1003
    //G90 G58 X14.927 Y0. Z10.
    //M97 P1003
    M5
    G91 G28 Z0.
    G28 Y0.
    M30
    N1002
    Z5.
    G1 Z0. F300.
    X25. F1200.
    G1 Y-25.
    G1 X-25.
    G1 Y25.
    G0 Z10.
    M99
    N1003
    Z5.
    G1 Z-1. F300.
    G0 Z10.
    M99
    As was previously stated you should use M97 and "N" in front of the subprogram number. I corrected it, see bold text. Antoher tip I would offer is to try and match the subprogram number with the tool number. If you have a lot of subs, you can easier reference them by doing this.
    You should also think about using // in front of the second sub call so you can use block delete to run the sub only once in case there are errors in the program.
    Sep 2007
    Sub
    That worked a treat.
    Thanks!
    Sep 2007
    I'm still working on trying to get Subprograms working. Just had a new VF-3SS delivered and we're setting up for multiple work offsets. Can someone take a look at the code below and tell me if there is an obvious problem.
    Thanks,
    O0000
    G00 G40 G49 G80 G90
    T6 M06 (10MM END)
    (MAX | Z2.)
    (MIN | Z-20.)
    G00 G90 G54 X72.5 Y51.15 S10000 M03
    G43 H6 Z2. M08
    M98 P0001
    G00 G90 G55 X72.5 Y51.15
    M98 P0001
    M05
    G91 G28 Z0. M09
    M01
    T4 M06 (6MM END MILL)
    (MAX | Z2.)
    (MIN | Z-20.)
    G00 G90 G54 X-38.1987 Y59.68 S11000 M03
    G43 H4 Z2. M08
    M98 P0002
    G00 G90 G55 X-38.1987 Y59.68
    M98 P0002
    M05
    G91 G28 Z0. M09
    G90
    M30
    O0001
    (10MM END - CONTOUR)
    G00 G90 X72.5 Y51.15
    Z2.
    Z1.
    G01 Z0. F700.
    X66.5 F2200.
    X60.5
    X-49.5
    X-55.5
    X-61.5
    G00 Z2.
    X-55.5 Y61.15
    Z1.
    G01 Z-5. F700.
    X-49.5 F2200.
    X60.5
    X66.5
    G00 Z2.
    X-55.5
    Z-4.
    G01 Z-10. F700.
    X-49.5 F2200.
    X60.5
    X66.5
    G00 Z2.
    X-55.5
    Z-9.
    G01 Z-15. F700.
    X-49.5 F2200.
    X60.5
    X66.5
    G00 Z2.
    X-55.5
    Z-14.
    G01 Z-20. F700.
    X-49.5 F2200.
    X60.5
    X66.5
    G00 Z2.
    X60.5 Y48.95
    Z1.2
    G01 Z-3.35 F700.
    Y61.65 F2200.
    G00 Z2.
    Y48.95
    Z-2.35
    G01 Z-6.9 F700.
    Y61.65 F2200.
    G00 Z2.
    X25. Y45.6036
    Z1.2
    G01 Z-3.35 F700.
    Y51.95 F2200.
    Y58.6885
    G00 Z2.
    Y45.6036
    Z-2.35
    G01 Z-6.9 F700.
    Y51.95 F2200.
    Y58.6885
    G00 Z2.
    X-13. Y45.6036
    Z1.2
    G01 Z-3.35 F700.
    Y51.95 F2200.
    Y58.6885
    G00 Z2.
    Y45.6036
    Z-2.35
    G01 Z-6.9 F700.
    Y51.95 F2200.
    Y58.6885
    G00 Z2.
    X-49.5 Y48.95
    Z1.2
    G01 Z-3.35 F700.
    Y61.65 F2200.
    G00 Z2.
    Y48.95
    Z-2.35
    G01 Z-6.9 F700.
    Y61.65 F2200.
    G00 Z2.
    M99
    O0002
    (6MM END MILL - CONTOUR)
    G00 G90 X-38.1987 Y59.68
    Z2.
    Z1.
    G01 Z-7. F2000.
    G02 Y45.72 I0. J-6.98 F1000.
    Y59.68 I0. J6.98
    G01 Y57.88
    G02 Y47.52 I0. J-5.18
    Y57.88 I0. J5.18
    G01 Y57.68
    G02 Y47.72 I0. J-4.98
    Y57.68 I0. J4.98
    G00 Z2.
    X-25.8013 Y59.68
    Z1.
    G01 Z-7. F2000.
    Y59.68 I0. J6.98
    G01 Y57.88
    Y57.88 I0. J5.18
    G01 Y57.68
    Y57.68 I0. J4.98
    G00 Z2.
    X-.1987 Y59.68
    Z1.
    G01 Z-7. F2000.
    Y59.68 I0. J6.98
    G01 Y57.88
    Y57.88 I0. J5.18
    G01 Y57.68
    Y57.68 I0. J4.98
    G00 Z2.
    X12.1987 Y59.68
    Z1.
    G01 Z-7. F2000.
    Y59.68 I0. J6.98
    G01 Y57.88
    Y57.88 I0. J5.18
    G01 Y57.68
    Y57.68 I0. J4.98
    G00 Z2.
    X37.8013 Y59.68
    Z1.
    G01 Z-7. F2000.
    Y59.68 I0. J6.98
    G01 Y57.88
    Y57.88 I0. J5.18
    G01 Y57.68
    Y57.68 I0. J4.98
    G00 Z2.
    X50.1987 Y59.68
    Z1.
    G01 Z-7. F2000.
    Y59.68 I0. J6.98
    G01 Y57.88
    Y57.88 I0. J5.18
    G01 Y57.68
    Y57.68 I0. J4.98
    G00 Z2.
    X-47.9 Y60.65
    Z-6.
    G01 Z-11.3333 F2000.
    Y59.75 F1000.
    G03 X-47. Y58.85 I.9 J0.
    G01 X-36.
    G02 X-32.35 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X-37.5 Y46.8 I-5.15 J0.
    G01 X-45.5
    G02 X-50.65 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X-47. Y58.85 I3.65 J0.
    G03 X-46.1 Y59.75 I0. J.9
    G01 Y60.65
    X-47.9
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X-36.
    G01 Y51.95
    G01 X-45.5
    G01 Y55.2
    G01 Y60.65
    X-47.9
    Z-20. F2000.
    Y59.75 F1000.
    G01 X-36.
    G01 Y51.95
    G01 X-45.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X-28.9
    Z-6.
    Y59.75 F1000.
    G03 X-28. Y58.85 I.9 J0.
    G01 X-17.
    G02 X-13.35 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X-18.5 Y46.8 I-5.15 J0.
    G01 X-26.5
    G02 X-31.65 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X-28. Y58.85 I3.65 J0.
    G03 X-27.1 Y59.75 I0. J.9
    G01 Y60.65
    X-28.9
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X-17.
    G01 Y51.95
    G01 X-26.5
    G01 Y55.2
    G01 Y60.65
    X-28.9
    Z-20. F2000.
    Y59.75 F1000.
    G01 X-17.
    G01 Y51.95
    G01 X-26.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X-9.9
    Z-6.
    Y59.75 F1000.
    G03 X-9. Y58.85 I.9 J0.
    G01 X2.
    G02 X5.65 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X.5 Y46.8 I-5.15 J0.
    G01 X-7.5
    G02 X-12.65 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X-9. Y58.85 I3.65 J0.
    G03 X-8.1 Y59.75 I0. J.9
    G01 Y60.65
    X-9.9
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X2.
    G01 Y51.95
    G01 X-7.5
    G01 Y55.2
    G01 Y60.65
    X-9.9
    Z-20. F2000.
    Y59.75 F1000.
    G01 X2.
    G01 Y51.95
    G01 X-7.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X9.1
    Z-6.
    Y59.75 F1000.
    G03 X10. Y58.85 I.9 J0.
    G01 X21.
    G02 X24.65 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X19.5 Y46.8 I-5.15 J0.
    G01 X11.5
    G02 X6.35 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X10. Y58.85 I3.65 J0.
    G03 X10.9 Y59.75 I0. J.9
    G01 Y60.65
    X9.1
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X21.
    G01 Y51.95
    G01 X11.5
    G01 Y55.2
    G01 Y60.65
    X9.1
    Z-20. F2000.
    Y59.75 F1000.
    G01 X21.
    G01 Y51.95
    G01 X11.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X28.1
    Z-6.
    Y59.75 F1000.
    G03 X29. Y58.85 I.9 J0.
    G01 X40.
    G02 X43.65 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X38.5 Y46.8 I-5.15 J0.
    G01 X30.5
    G02 X25.35 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X29. Y58.85 I3.65 J0.
    G03 X29.9 Y59.75 I0. J.9
    G01 Y60.65
    X28.1
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X40.
    G01 Y51.95
    G01 X30.5
    G01 Y55.2
    G01 Y60.65
    X28.1
    Z-20. F2000.
    Y59.75 F1000.
    G01 X40.
    G01 Y51.95
    G01 X30.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X47.1
    Z-6.
    Y59.75 F1000.
    G03 X48. Y58.85 I.9 J0.
    G01 X59.
    G02 X62.65 Y55.2 I0. J-3.65
    G01 Y51.95
    G02 X57.5 Y46.8 I-5.15 J0.
    G01 X49.5
    G02 X44.35 Y51.95 I0. J5.15
    G01 Y55.2
    G02 X48. Y58.85 I3.65 J0.
    G03 X48.9 Y59.75 I0. J.9
    G01 Y60.65
    X47.1
    Z-15.6667 F2000.
    Y59.75 F1000.
    G01 X59.
    G01 Y51.95
    G01 X49.5
    G01 Y55.2
    G01 Y60.65
    X47.1
    Z-20. F2000.
    Y59.75 F1000.
    G01 X59.
    G01 Y51.95
    G01 X49.5
    G01 Y55.2
    G01 Y60.65
    G00 Z2.
    X-47.3 Y59.3
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X-47. Y58.7 I.3 J0.
    G01 X-36.
    G02 X-32.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X-37.5 Y46.95 I-5. J0.
    G01 X-45.5
    G02 X-50.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X-47. Y58.7 I3.5 J0.
    G03 X-46.7 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    X-28.3
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X-28. Y58.7 I.3 J0.
    G01 X-17.
    G02 X-13.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X-18.5 Y46.95 I-5. J0.
    G01 X-26.5
    G02 X-31.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X-28. Y58.7 I3.5 J0.
    G03 X-27.7 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    X-9.3
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X-9. Y58.7 I.3 J0.
    G01 X2.
    G02 X5.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X.5 Y46.95 I-5. J0.
    G01 X-7.5
    G02 X-12.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X-9. Y58.7 I3.5 J0.
    G03 X-8.7 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    X9.7
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X10. Y58.7 I.3 J0.
    G01 X21.
    G02 X24.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X19.5 Y46.95 I-5. J0.
    G01 X11.5
    G02 X6.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X10. Y58.7 I3.5 J0.
    G03 X10.3 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    X28.7
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X29. Y58.7 I.3 J0.
    G01 X40.
    G02 X43.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X38.5 Y46.95 I-5. J0.
    G01 X30.5
    G02 X25.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X29. Y58.7 I3.5 J0.
    G03 X29.3 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    X47.7
    Z1.
    G01 Z-20. F800.
    Y59. F1000.
    G03 X48. Y58.7 I.3 J0.
    G01 X59.
    G02 X62.5 Y55.2 I0. J-3.5
    G01 Y51.95
    G02 X57.5 Y46.95 I-5. J0.
    G01 X49.5
    G02 X44.5 Y51.95 I0. J5.
    G01 Y55.2
    G02 X48. Y58.7 I3.5 J0.
    G03 X48.3 Y59. I0. J.3
    G01 Y59.3
    G00 Z2.
    M99
    Registered Caue's Avatar
    Apr 2009
    Brazil
    It's not clear if you are putting the main program and the two subroutines into the same file or as three different files in the mamory (because the % sign appearing only once). If you are using the three sequences in the same file, the solution is the same then before (replace M98 by M97 code ande the subprogram names O0001 and O0002 by N0001 and N0002).
    Using this way (local subroutines instead of external subroutines) is always a good choice for testing about such these problems.
    Good Luck!
    Apr 2009
    Brazil
    I've just ran your code downhere at HFO and found no problems with the structure (only some alarms related to circle interpolation coordinates).
    I used 3 different files.
    If the problem persists, please post or e-mail me. caue.nascimento@bol.com.br
    Sep 2007
    Thanks for your help,
    I stopped using the post I was trying and instead used Transform toolpath (Mastercam) with my old post. Worked fine. I do understand about the separate programs needing to be on memory now and they do separate when I copy them from Net Share to memory. I'm on a steep learning curve right now and I do appreciate your patience.
    Thanks to all.
    1. Help with subprogram
      By 69owb in forum G-Code Programing
      Last Post: 09-05-2008, 06:06 PM
    2. eia subprogram
      By rs1982 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 04-11-2008, 09:10 AM
    3. having trouble with subprogram
      By dshowald in forum Milltronics
      Last Post: 02-10-2007, 03:32 PM
    4. Restarting an EIA subprogram
      By ajl6549 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 08-09-2006, 07:06 AM
    5. Mazatrol subprogram
      By BeanO in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 11-24-2005, 04:12 AM
