Old 03-17-2009, 10:38 AM
behindpropeller is on a distinguished road
Marposs Tool Setter accuracy
I ran a bunch of tools on our marposs toolsetter last night.
Length measuring is coming out to be +/-.0001
When having it measure the diameter of a tool I am getting +/-.020+
I'm taking some gauge pins home this evening to re-calibrate it but wanted to ask if there were any settings I should check??
Tim
Old 03-17-2009, 07:14 PM
Haas_Apps is on a distinguished road
Somethings Wrong
I don't know what it is but something is wrong. Call Haas or Call Marposs.
Tim
Old 03-17-2009, 09:45 PM
I will after I re-calibrate it. The biggest problem is that everybody at haas seems to know nothing about the marposs equipment.
Old 12-07-2011, 08:21 AM
r3ptile is on a distinguished road
Although my laser is on an okuma vmc, I am having the same issue you are; no one seems to know anything about them. I have yet to be able to find any osp programs/subprograms that will check tool diameter. I keep getting told that "no one uses the laser to check diameter", which blows my mind. I would love to get my hands on information about programming the damn thing, all I have been able to find is an installation manual.
Have you inspected the laser to make sure its tightened down to the table? The air pressure from the laser blower could be shifting it when it checks the cutters.
Also, is it possible that your tool holders or spindle chuck cavity has wear or damage and is giving you runout?
Lastly, have you tried hand indicating the cutters when they're in the spindle to check run-out and diameter. For fussy jobs, I usually indicate every tool in the spindle rite off the bat. I rarely have been over .0004.
Old 12-07-2011, 09:12 AM
Machineit's Avatar
Machineit is on a distinguished road
UH, the post is over 2 1/2 years old, I'm guessing that it has been resolved.
Haas VF-2, HA5C, BobCAD V23
Old 12-07-2011, 09:14 AM
Actually, it has not. I just have not had the time to mess with it.
Old 12-07-2011, 09:20 AM
Delw is on a distinguished road
well sence its still going,
make sure the pad is tight and square, then do all your calibration.
those pads come loose every once in a while. use a heigth gage and get it within .0001 flatness.
Delw
Old 12-07-2011, 12:05 PM
WallyL7's Avatar
WallyL7 is on a distinguished road
???WOW!!!!
Fix that thing already! Doesn't take long to tram the Renishaw one and calibrate it - maybe 30 minutes at most!
Tim
Old 12-07-2011, 12:12 PM
Originally Posted by WallyL7 View Post
???WOW!!!!
I have run the calibration program a few times. The problem with my marposs is that the diameter seems to never be correct.
I only use my machine for short runs and prototypes. I'm not a job shop running 100s of jobs per week.
Tim
Old 12-09-2011, 08:52 AM
is it giving you diameter errors when you check the tool that you use for the calibration program?
If so have you tried checking the reference tool for any type of run out? It is possible that that tool got bumped and is off, there-for screwing up your calibration, furthermore screwing up everything afterwords.
Its a long shot but an easy fix if that's whats going on.
You could also try indicating the laser itself to make sure its still square and hasn't been moved at all. If it was bumped at all then it wont be lined up with the work offset in the calibration and gauging programs.
  #11   Ban this user!
Old 12-09-2011, 02:26 PM
The last time I set it up I checked the diameter and runout with a friends presetter.
Like I said.... Don't have a lot of time to mess with it and there is no section on troubleshooting it.
  #12   Ban this user!
Old 12-09-2011, 04:45 PM
underthetire is on a distinguished road
Seems to be some confusion here whether it's a laser type or probe type. Laser types can have issues with tool diameter for sure.
Tool Pre Setter Allen123 Mach Software (ArtSoft software) 0 03-15-2009 11:29 PM
Need Help!- Tool Setter Macro for M-V60C and Metrol Setter mitshack Mazak, Mitsubishi, Mazatrol 0 10-06-2008 08:39 AM
Need Help!- Tool setter macro for M-V60C and Metrol setter mitshack General CNC (Mill and Lathe) Control Software (NC) 0 10-06-2008 08:38 AM
Tool Setter GARY DAVIS Fadal 6 03-18-2008 07:44 PM
tool setter ACME General Metalwork Discussion 8 07-30-2005 11:15 AM
