Old 03-12-2009, 08:57 PM
robard is on a distinguished road
Changing S/N setting 26 to cancel alarm 144
I had an alarm 144 on my TM-1 yesterday. Machine paid in full on purchase and the local HFO gave me a serial no. to overwrite the one listed at setting 26. My control will not let me overwrite it. The service tech said to page down to setting 26 and type in new number and hit enter but my control will not change the existing number. Does anyone know what I am doing wrong? I can call the HFO in the morning but I thought I might cast a line tonight and see what might bite!! I guess I have little patiience...LOL. Thanks in advance,
R Ardoin
Old 03-12-2009, 09:01 PM
rlabonte18 is on a distinguished road
If I remember right you need to turn setting 7 parameter lock off first. When you enter the number in 26 the number doesn't change but clears the alarm.
Old 03-12-2009, 09:16 PM
Wow!! Thanks to you and the CNC community for such a quick response. I didn't think about having to turn parameter lock off. I guess I just hit E-STOP then toggle to parameter 7, change lock to off then proceed. Thanks labonte18. Hope I can return the favor one day.
R Ardoin
Old 03-12-2009, 09:47 PM
Originally Posted by robard View Post
...I guess I just hit E-STOP then toggle to parameter 7, change lock to off then proceed....R Ardoin
Actually you turn off Setting 7, not Parameter 7.
Old 03-12-2009, 09:52 PM
Got it. Thanks Geof!
Old 03-14-2009, 11:32 AM
b7may is on a distinguished road
I have done this on many machines. You are not changing the serial number, you are unlocking the code. If nothing happens then everything worked. If you turn the machine off and back on and do not get the alarm you are good.
Setting 7 allows you to change parameters not settings.
How i cancel G92 command? shaikaa1 Haas Mills 6 02-28-2009 08:37 PM
How Do You Cancel an Ad on CNCZONE Gene-Yo Forum Questions or Problems 1 01-29-2009 08:45 PM
changing result of alarm spock Sharp CNC 2 01-26-2008 09:35 AM
Cancel a Posting Mr.Chips Forum Questions or Problems 7 01-16-2007 05:35 PM
Feed/Rapid o'ride cancel? ajl6549 Mazak, Mitsubishi, Mazatrol 0 11-02-2006 05:32 AM
