Old 03-04-2009, 10:16 AM
penjas14 is on a distinguished road
Rotary ?
On a haas rotary if you make a cut that goes down a shaft to an A of lets say 7000, when you go for your next cut does it need to unroll itself or can it just pick back up on 7000 and go to 14000?
Old 03-04-2009, 10:33 AM
Yes you can program A7000. for the first cut and A14000. for the next but I think a limit comes up because you cannot input more than 5 digits ahead of the decimal or something like that.
But you do not need to 'unroll' the full 7000. Look up QUICK ROTARY G28 in the Manual. It is either a SETTING or a PARAMETER or both; actually there are two functions that have to be turned on. One is QUICK ROTARY G28 and the other is CIRCLE WRAP.
When these are on and you command G28 A0. the rotary will unroll to the closest zero point. For instance if you are at 361.0 it will unroll 1 degree and home there, if you are at 359.0 it will unroll 359 degrees.
In your case 7000.0 is a little bit past 19 revolutions which is 6840.0 so your rotary will unroll 160. degrees and home there.
Old 03-05-2009, 10:07 PM
shawnc74361 is on a distinguished road
I make a traverse shaft on my rotary that is X26 in and A9000 deg and it goes back to X0 and to A18000 then does the quick origin and makes another pass. The A axis will continue till it hits A99999 then it will reset.
Old 03-08-2009, 10:42 PM
crabbass is on a distinguished road
consider using incremental programming, followed by a G28. A0.
this will allow you to take multiple passes with the same A7000. imput before each cut.
Need Help!- Help with rotary table woodsnskins Benchtop Machines 5 12-18-2008 11:56 AM
hrs 310 rotary anslee Haas Mills 0 11-19-2008 09:30 AM
Rotary Tables Jack772 Benchtop Machines 4 10-07-2008 09:48 AM
rotary help dpark1 Mastercam 1 09-10-2007 07:35 PM
help with rotary quemast GibbsCAM 1 05-27-2007 12:16 PM
