I'm planning on using a .03, and .02 carbide endmills on my table tool setter in my VF-2 and the feed rate seems awfully high for that small of a tool. Seems like it may chip at that initial feed rate at first touch. What do you guys do? and how small of a tool have you successfully touched off on the probe.? Thanks |
| I have chipped .125 end mills and have not .047 end mills. It really depends on how clean the tool setter is. I have ran some .015 end mills in a HAAS before but I did not use the tool setter. I personaly would use brass shim stock and do it manually. |
| I use the tool setter for 1/32" endmills frequently. At first I manually reduced the feed rate but then forgot to later. No chiped tools yet. So I don't bother to reduce the feed rate on those anymore (short and relatively stiff). I still reduce the feed for .05 and smaller drills however. |
| Using the toolsetter with the tool rotating slows the feed down also. You just put a rough height in, and it stops above, turns the spindle on reverse, and eases down onto the setter. Not sure if that speed would chip the tool. P9853 (I believe)
__________________ Tim |
| I never recommend going below 1/32 on a contact tool setter...have I gone smaller successfully? Yes, would I trust it every day? No. For what it's worth, your HFO can retrofit a non-contact tool setter into your probing package on the machine...it's expensive, but I have a customer setting a 0.002" tool every day with it (the particular model they have will go as small as 0.001"), as well as lots of other customers using them for various other reasons...they're a LOT faster than the contact probes are too...VERY VERY fast for broken tool detection too, make a rapid move into the beam by the tolerance specified, if it see's any light, it's broken, if it sees no light, it's good and makes a rapid move out...it's amazing how fast it is. |
| Need Help!- Tool Setter Macro for M-V60C and Metrol Setter | mitshack | Mazak, Mitsubishi, Mazatrol | 0 | 10-06-2008 08:39 AM |
| Need Help!- Tool setter macro for M-V60C and Metrol setter | mitshack | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-06-2008 08:38 AM |
| depth of cut for small dia tools | plastibob | General Metalwork Discussion | 1 | 08-05-2008 02:05 PM |
| Small multi-machine tools | thetrillionaire | Smithy | 2 | 12-24-2007 02:44 PM |
| sinks/small radius tools | bud | CNC Tooling | 1 | 01-03-2007 07:43 PM |
