Old 03-03-2009, 08:32 AM
panaceabea is on a distinguished road
Need help with tool length offset
I am having a little trouble figuring out the routine for setting tool length offset on the new Haas mill. I am new to haas but not machining, TLO on my other two mills is a simple single button setup from the jog page, touch the top of the block(of known height) with the tool , push the tool set button and its done .
I have followed the HAAS manual to a T (I Think) but I am guessing there is something simple I am missing or have screwed up. Here is the procedure I am following as best I understand it from the manual, page 58.
g54 z value is 0
load tool in the spindle
enter jog mode
jog tool down towards tool setter (gauge block in my case)
touch off on block
press ofset
page up until I am on geometry for the tool in the spindle
press tool ofset measure
press next tool
load next tool in spindle
touch off repeat etc .
All seems well and it loads the machine z position -**.*** shown into the tool table , the problem I am having is none of the tools are set at the correct offset .
When load the individual tools thru M06 T** and go back and check them for refrence against the gauge block none of them are set at the same place.
One of them , always the 1/2 endmill , no matter what T number is assigned to it , is always exactly at the top of the tool block but all the rest are at different hieghts.
They range from being almost an inch above the block to -1.2" (1.2" Below the top of the block)
I am sure I am just missing something simple here , the process seems simple enough once I figure out what I am doing wrong .
Old 03-03-2009, 08:55 AM
behindpropeller is on a distinguished road
g54 z value is 0
enter jog mode
touch off on block
press ofset
press next tool
Great post. I am having the same problem. I have a hard time following the manual.
Tim
Old 03-03-2009, 09:28 AM
That is puzzling. I normally load all the tools first then go back to the beginning and do the offsets:
Touch off tool on gauge block
Push Tool Offset Measure
Push Next Tool
repeat for all the tools.
That is no different to your procedure so why doesn't yours work.
No values in any work offsets you say so the Setting that selects for subtracting the work coordinate Z value from the tool offset should not be doing anything.
Check that Setting anyway. I cannot remember the number but it is called something like TOOL OSET MSR USES WORK ZERO.
Have you tried entering the tool offset value from the keypad? Touch the tool, type in the Z position at the bottom of the screem and press write. Do you get the same value entered this way?
It is sure to be something ridiculously simple.
Old 03-03-2009, 10:43 AM
Yes I have tried entering it manualy, same number, same problem,
I am going to call Haas tech in a few minutes and will update with what I am doing wrong
Old 03-03-2009, 11:23 AM
still not sure what I am doing wrong , the fellow explained how I need to enter the distance from the top of my touch off block to the table as a positive number in g54 z position before touching off and pressing measure tool offset key but it still hasnt solved the problem of tool offsets being wrong .
Check setting 64 for the "use work for tool offset" and its off .
Old 03-03-2009, 11:28 AM
lkenney is on a distinguished road
I set all my tooling to a 2" dial gage block, then change the G54, G55 etc Z axis for the different parts that we are machining.
I bring up the Offset screen which on my machine is 1-15 tools, have to flip to second screen for T16, install a tool in the spindle, crank down to the gage, could be a 1 2 3 block or the top of the vise, set tool to a standard zero on the gage or setup block, push tool offset and i am done with that tool.
When I load a program and then the first part, I load from the TC an end mill, bring it of the part somewhere that will be cut away if possible and running at about 1000 rpm bring the tool down to just touch the material usually only a very slim arc. I then subtract the tool zero length from the current tool height and page up the the part zeros and put in the calcualted offset in the G54-g55 etc Z position.
If I don't want to mark the material i will use a gage block, feeler gage or a piece of paper to get the tool close and subtract out the thickness of the block or feeler gage. The tool is not running when I take the measurement with these tools
Eagle
Old 03-03-2009, 12:43 PM
Thanks for the input, I am not debating the method by which we all touch off or otherwise measure TLO , the problem I am having is that when I push the measure tool length button it enters the number in the tool table, but none of the tool lengths (other than the .5") are correct
Old 03-03-2009, 12:49 PM
Check your setting 64. I can't find the thread on if it should be on or off without a toolsetter.
Tim
Old 03-03-2009, 12:56 PM
HuFlungDung's Avatar
Moderator
This 1/2" holder you say is always correct when measured. Even in a different pocket?
Any chance of some kind of mixup between metric/inch?
What is the machine Z position readout at the Z home? What is the Z position with the spindle nose touching the gauge block sitting on the table?
There's got to be a way of systematically discovering the error by measuring tool lengths to gauge line (use a height guage and a socket on the workbench), calculating what the length offset should be, then comparing those results with what the machine seems to be measuring.
Old 03-03-2009, 01:20 PM
Are the tools constantly off length? Please give us some actual numbers to work with. ie: tool one is measuring ____ length but when used is cutting xx" low or what ever is true.
Eagle
  #11   Ban this user!
Old 03-03-2009, 02:38 PM
I am at somewhat of a loss on how to proceed. I have cleared the tool library in an attempt to start over , the machine says tool 5 is in the spindle so I have insterted a 1/2" endmill in the spindle and homed the machine . readout says x0.00 y0.00 and z0.00 as expected. My tool setter is 5.00" off the table . When the 1/2" endmill is resting on the tool block the z axis reads -18.7601 . pushing the tool length offset measure button then enters that number in the length geometry box for tool 5.
At this point the manual indicates I should push the next tool button to advance to the next tool, I get an invalid tool number error message and cannot proceed. As there are no other tools entered in the tool library I cant callout m6 T** to advance . Not sure how to get the machine to put tool 5 back in the carousel and let me load the next tool. Worked earlier using the next tool button as described in the manual
  #12   Ban this user!
Old 03-03-2009, 03:07 PM
If I am putting a whole series of tools in order I load the first tool (usually t2 as i like to keep tool 1 open if i can) then put the tool in the spindle and measure it, then push ATC FWD which will take the put the tool first tool in the ATC and advance the ATC one tool, repeat until you are loaded. If I am putting in select tooling then I hit the MDI button key one time so not to invoke DNC and key in "T6" or what ever tool I want to work with then punch either the ATC Fwd or ATC REV button.
Should work for you.
Let us know.
Eagle
Tool # and length offset agreement Vern Smith Haas Mills 11 12-17-2008 07:42 PM
Absolute readout & tool length offset leeroy General CNC (Mill and Lathe) Control Software (NC) 4 11-07-2008 03:35 PM
Editing post for tool length offset? Chuck Reamer Post Processors for MC 5 09-11-2007 10:38 PM
Tool Length offset? cncuser1 G-Code Programing 3 08-30-2007 08:59 PM
NC reading tool length from offset page, not data page..? RMagnusson Mazak, Mitsubishi, Mazatrol 1 03-21-2006 04:07 PM
