Old 03-01-2009, 04:24 PM
homezz is on a distinguished road
Beacon Light
Does anyone know how to install a beacon light for a 2001 Haas mini mill. My machine didnt have one and I was able to get a light with a small amount of wire still atached. I was wondering if anyone could tell me the wire diagram to get it working. This is the light that is on top of the controller and it is green when the machine is runnign and it will go red when the machine alarms.
Old 03-01-2009, 07:15 PM
Have a look inside the big tube supporting the monitor housing, inside the monitor housing and inside the control cabinet. If you are lucky you will find a wire labelled Green Beacon or something like that not connected to anything at the top.
I have found Haas prewires a lot of things which are options so the wires are just sitting there unused.
Old 03-02-2009, 09:53 AM
I looked in the tube and back of the cabinet and found nothing. I did locate where the connector would go on the main board. If anyone has the diagram that would be the best.
Old 03-11-2009, 09:35 PM
I was able to find the plug on the PC board( it is labeled "BEACON") and I have ordered some molex mini fit jr from digikey so I can wire it in myself. I know what a multimeter is but I barley know how to use one. Can anyone guide me thru identifing which pins would power the green light, red light , the common and ground pins. I want to get it right so I dont smoke my machine
Old 03-11-2009, 10:57 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Man, it's just not worth it. Call Haas and just order the right harness. It can't be that expensive.
They've had a few different types of beacons over the years (and I think some of them used incandescent bulbs). They might all use different drive voltages and amperages. It's just not worth messing up your board for a blinking light. The right parts from Haas will just plug in and you'll be done.
Greg
Old 03-12-2009, 12:52 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
You might be better off calling HAAS as "Donkey Hotey" suggests. You might find it to be very inexpensive not to mention the correct harness. If you make any mistake your ony going to have to call them anyway, but with a larger more expensive problem.
Do yourself a favor and just get a quote.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
a ring of 200 Led Lights to light up? light source render? Rich05 Solidworks 6 10-25-2008 06:16 PM
Spectra light and Light machine owners have ? ZipSnipe Benchtop Machines 11 07-18-2008 09:52 PM
Problem- VF-2 Work Light Out akedward Haas Mills 19 02-19-2008 12:37 PM
320 fault Light Ed Williams Gecko Drives 0 02-05-2008 09:28 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 08:08 AM
