Old 02-24-2009, 06:16 PM
wsbat is on a distinguished road
VF-2 1998
I have a haas 1998 VF-2 and it has a high pitch squeel at high RPM`S do`s anybody have this problem or no now to fix it.
Old 02-25-2009, 04:10 PM
WallyL7's Avatar
WallyL7 is on a distinguished road
Did you turn down the volume nob?
HA - sorry
Did it just start doing it? Is the machine new to you? Some of the machines make a pretty loud "soundwave" at certain rpm's. Are you real familiar with the Haas' enough to know if it could just be "normal"? I have had machines make similar sounds and that was just what they did...
Post a video of it making the noise.
I would imagine that some of the guys here who like to fix stuff would be able to help you out, but otherwise just call Haas service.
Tim
Old 02-26-2009, 08:19 AM
I had this machine four two years and it ben doning all along. I haven`t ben around other haas machine maybe it`s normal.
Old 02-26-2009, 08:31 AM
Sometimes it is the motor and spindle pulleys not aligned correctly so the belt rides against the side of the pulley. If you are feeling energetic pull the covvers off and see if the belt runs centered in the pulley; if it is offset one way on the motor and the other way on the spindle you may need to re-align things.
Need Help!- parameters for cincinnati arrow 1000 (1998) aherrc Machine Problems, Solutions , Wireless DNC, serial port 1 04-25-2008 02:04 PM
1998 Cinncinatti Arrow 1000HT...Feedback Please AMSengineering General Metal Working Machines 0 01-06-2008 07:19 PM
How Fast Can a 1998 VF3 Machine 3d Contours? Rocko1 Haas Mills 12 09-08-2007 10:57 AM
Colchester Combi 4000 (1998) gollame Machine Problems, Solutions , Wireless DNC, serial port 1 07-31-2007 11:55 AM
