I had a tool change error this evening. It happened on the change to the probe. Well I hit recover, and put something soft under the tool changer (couple of pieces of foam) and it dropped fine.... but it got the crash pin on my tool setter. I think I will move the tool setter to the opposite side of the table now. Tim |
| Tim |
| I do not want to add to the collection of scars on my fingers.
| If something happens to trigger an alarm during a toolchange the machine stops. Then when the alarm is cleared, if the toolchanger will still function the machine may not know where things are so it may try to retract the shuttle with the spindle still down over the tool, bring the shuttle in with a full pocket and a tool in the spindle or other unpredictable behaviour. The Recover procedure steps through asking questions such as 'is the pocket empty', 'is there a tool in the spindle', etc., and you press N or Y for it to continue. Sometimes the spindle may be partly retracted from putting a tool in the pocket and this tool may fall out or get knocked out when the spindle moves so it is a good idea to put something under it. When it is a case of the spindle over a tool in the pocket it is risky to get your hand near because you cannot guarantee it will not kick sideways when things move.
| I see the confusion. I have a side mount tool changer and it sounds like it's much less risky to hold the tool during the recover process. With a SMTC, you manually (repeatedly pushing the ATC forward/reverse button) move the arm back to its home. I think it's in 1º incriments so it's easy to see if there is a bad situation developing. Plus, if there's any unordinary loads on the arm, you can see that the arm is slightly bent so you know to be more cautious. |
#10
| If you're worried about it, I'm tempted to think that the better solution is to make a simple protective cover for your toolsetter. |
#11
| Geof, Thanks for the clear description of tool recovery. I don't have a CNC yet but there will be a Haas in my garage sometime in the future. Probably one of the older "plastic" machines due to $$. I'm hanging out on a couple of CNC forums trying to learn whatever I can in the meantime. Ralph |
#12
| Tim |
| Help with Gcode for toolsetter | Harryman | WinCnc | 4 | 01-10-2009 11:00 AM |
| Need Help!- Toolsetter problems | inertialabs | Haas Mills | 6 | 10-23-2008 02:51 PM |
| Probe and toolsetter suggestions? | REVCAM_Bob | General Metal Working Machines | 15 | 12-31-2007 06:12 PM |
| Building Touch Probe and Toolsetter... | REVCAM_Bob | General Electronics Discussion | 9 | 05-23-2007 06:43 AM |
| Mazak / Yasnak MX3 control toolsetter | soszi1950 | Mazak, Mitsubishi, Mazatrol | 1 | 02-10-2007 08:24 AM |
