Old 02-17-2009, 07:53 AM
mmodeler is on a distinguished road
HAAS VF2 DNC buffer problem
I am trying to DNC a large program at 19200 baud rate and the buffer fills. At that point the handshake between machine and computer loses information and a error is the result. I am using a RS232 cable about 20' long. Anybody seen this?
Old 02-18-2009, 01:55 AM
lkenney is on a distinguished road
slow your baud rate down so the machine can stay ahead of the data flow.
Old 02-18-2009, 04:14 AM
CNC Viking's Avatar
CNC Viking is on a distinguished road
mmodeler,
I have a 1996 Feeler FV-800 with Mitsubishi Meldas 520 AM control and have no problem drip feeding at 19 200 Baud with a 20' serial cable between my PC and the front panel. Remember that there is also a 22' internal intermediate cable from the front panel to the control at the back. Total L=42' !
I have the CNC parameters set to Hardware (RTS/CTS) handshake:
PARAMETER 1
#. Parameter input (value)
2. Baud rate: 0 (19200 Baud)
3. Stop Bit: 3 (2 stop bits)
3. Parity Effective: 0 (No Parity bit during I/O)
5. Even Parity: 0 (Odd Parity)
6. Chr Length: 3 (8 data bits) this is a little special with Mitsubishi controls.
7. Terminator Type: 3 (EOR is fixed no matter what you choose)
11. Hand Shake: 1 (RTS/CTS Hardware)
12. DC Code Parity: 0 (No DC code parity)
PARAMETER 2
#. Parameter Input (value)
1. DC2/DC4 Output: 0 (Without DC2, without DC4)
2. CR output: 1 (On)
3. EIA Output: 0 (ISO)
4. Title Feed out: 0 (Off)
5. Feed Chr:0 (0 Characters)
6. Parity V:0 (Off)
7. Time Out:0 (0 seconds)
8. RST Ignore:0 (RST valid)
PC parameters for COM1 serial port
Baud rate: 19200
Data Bits: 7
Parity: Even
Stop Bits: 2
Flow control: Hardware
FIFO buffers in "Advanced" are set to "LOW".
DNC program parameters
Com port: COM1
Baud rate: 19200
Flow control: RTS/CTS
Code system: ISO
Data bits: 7
Parity: Even
Stop bits: 2
Serial cable pinout (20' Belden 8104 shielded low capacitance cable):
PC side 9-pin Dsub female <---> CNC side 25 pin Dsub male
2 RxD <---> 2 TxD
3 TxD <---> 3 RxD
5 Signal Ground <---> 7 Signal Ground
7 RTS <---> 5 CTS
8 CTS <---> 4 RTS
Pins 4 DTR & 6 DSR are jumpered at PC side's 9-pin Dsub female
Pins 6 DSR & 20 DTR are jumpered at CNC side's 25-pin Dsub male
Pin 8 is not used at my CNC side's 25-pin Dsub male, but may need be jumpered to 6 & 20 for your CNC. Please check this.
/ Peter
Old 02-18-2009, 08:08 AM
dcoupar's Avatar
Are you wired to a com port on the PC or are you using a USB to serial adapter? Hardware handshake?
Old 02-18-2009, 08:13 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
I'm also wondering if the buffer is loading so much information that the PC thinks the connection was lost after a certain amount of time (waiting for the machine to respond back). Is there a time-out setting on the communication software?
Greg
Old 02-19-2009, 02:59 PM
I am using a com port.
Lines are being lost. the computer does not send the information fast enough I think.
Old 02-19-2009, 03:16 PM
Drop the baud rate to 9600 on both the pc and the haas and see if the trouble continues
Eagle
Old 05-27-2009, 06:11 PM
gm3211 is on a distinguished road
Also make sure you disable the FIFO on the local comm port. You could also try using RTS/CTS (hardware flow control) if you have a cable that is wired this way. If you need help still, feel free to give us a call. We have lots of experience in connecting this machine and cabling.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
NO BUFFER WITH DRIP FEED Stebedeff Fanuc 2 01-17-2009 06:53 AM
show z buffer 1ctoolfool Rhino 3D 3 01-07-2009 02:56 AM
Parallel port buffer eviljinks Australia, New Zealand Club house 0 05-30-2008 06:16 AM
Fanuc O-M Buffer inthezone Fanuc 7 07-24-2007 02:45 PM
DNC-Buffer overload problem Fish Machine Problems, Solutions , Wireless DNC, serial port 12 07-18-2005 11:52 AM
