Old 02-06-2009, 08:34 AM
Fairlane6t9 is on a distinguished road
HAAS VF0 Z Offsets
Hi all...have a HAAS VF0 from 1993, and having an issue with z offsets. When I enter a positive value in the Z registry in G54, the spindle moves down. When a negative number is entered, the spindle moves up. Is this just because it's an older version of the HAAS software, or is there something I'm missing. I know on the newer controllers, setting a negative number in Z in G54 moves the plane down and a positive moves the plane up. Any ideas, or is there something I'm missing? I'm relatively new at this, so go easy on me.
Old 02-06-2009, 10:01 PM
dcoupar's Avatar
You might check Parameter 57 "NEG WORK OFS".
Old 02-09-2009, 07:07 AM
Z axis offset problems
Parameter 57 on this machine is "EXACT STOP CANNED X-Y". The only other parameter I see dealing with this is Parameter 64 "T OFS MEAS USES WORK". This was set to on, I have since set it to off, but no change as far as the work offset is concerened. A negative number raises the plane, and a positive number lowers the plane. Is there a Z axis plane flip? Or, is this just a primitive version of the HAAS software and just something that I'll have to adjust to?
Old 02-09-2009, 09:34 AM
pit202 is on a distinguished road
Parameters are not Settings !
Old 02-09-2009, 09:44 AM
pit202 is correct.
Parameter 57 Common Switch is a whole bunch of different things that can be turned on or off with either a 1 or a 0. The Neg Wk Ofst is down near the bottom of the list.
To change a Parameter you need to turn Setting 7 Parameter OFF and push E-stop.
Old 02-09-2009, 10:11 AM
Z Offsets
Pit202, you are absolutely correct. I needed to be in PARAMETERS, not SETTINGS....I see parameter 57 and the neg work offset. I am changing it to "1" now. Thanks for the input.
Old 02-09-2009, 10:27 AM
Z porblem solved
Thanks for your replys, they helped tremendously. My issue is now resolved. Let's see what other issues I encounter as I really get into this machine!!!!
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
H and D offsets CNCMike Fanuc 11 05-27-2008 10:33 AM
Haas G54 - G60 Work Coordinate Offsets truline Haas Mills 8 09-04-2007 03:51 PM
Can the Haas do "G54P1" style offsets. Mike Mattera G-Code Programing 5 06-23-2007 04:53 PM
HAAS RS232: Include offsets with Main Prog? Rekd Machine Problems, Solutions , Wireless DNC, serial port 2 06-12-2003 06:28 PM
