Old 01-29-2009, 09:55 AM
Rocko1 is on a distinguished road
Adding Memory to older VF3
I know this has been discussed in the past but not with any real information. We have a VF3 year 1998, with 1mb memory. We currently DNC for large 3d programs. The price for adding the 16mb memory is quite high being around $1,400.00. I find this to be an overcharge in my opinion. Has anyone upgraded the memory on their own. If so can you provide instructions and where to locate the memory chip. Thanks
Old 01-29-2009, 12:01 PM
xiondavis is on a distinguished road
The memory is soldered to the board. When I upgraded my 2005 mini mill, they came out and swapped the 1mb board for a 16mb board.
Probably couldn't do it yourself - maybe you can solder the ram on the board (the boards looked the same, minus the chips) and set the params yourself, but I wouldn't try it...
Old 01-29-2009, 12:10 PM
HuFlungDung's Avatar
Moderator
When I had this upgrade done on my 96 VF3, I also needed an updated Mocon board. That might be something to inquire about. Of course, they will give a core price on the return of the old board, so that makes it not so pricey. But I think the complexity goes up then because software needs to be reloaded and purchased options turned back on. That's what I gathered from the tech who did the work for me (2000 miles away, before the machine was shipped to me).
Old 01-29-2009, 01:12 PM
Thanks for the info guys.
Old 01-29-2009, 01:53 PM
dafowfidy is on a distinguished road
Sorry if I am in left field but I am new to Haas, I come from a Fanuc/Okuma control background. Anyway on the older Mori Seiki's with Fanuc controls we simply added a hard drive and networked to it through an Ethernet cable like it was another computer. Is that possible with the Haas control?
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
older daewoo puma 10 caleb505 Daewoo/Doosan 0 08-05-2007 11:18 AM
older minimill2 jpatter@bellsou Benchtop Machines 8 07-29-2007 11:58 AM
Older controllers flatbottom General CNC (Mill and Lathe) Control Software (NC) 12 11-27-2005 06:50 AM
Software for an older machine? CamWest Commercial CNC Wood Routers 1 07-08-2005 09:02 AM
