Old 01-29-2009, 08:24 AM
Rocko1 is on a distinguished road
Haas VF3 Can it use nurb tool paths?
I decided to start seeing if our 1998 Haas VF3 can utilize toolpaths for our 3axis mold work beyond the Smoothed Line Segments that we currently output via CAM. We have several options on our toolpath generation as follows for 3 axis cuts:
1) Smoothed Line Segments (we currently use)
2) Arcs
3) Nurbs Spline Curve (nurb spline interpolation)
Does the Haas of our age able to do the Arc or Nurbs? thanks
Old 01-29-2009, 09:56 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Arcs and lines: yes. Splines: no.
Are you using Mastercam? MCX has an output option where you specify the tolerance for linearization or arc conversion. Other programs are probably similar.
I got better results and smoother operation by using Arcs. The file size was also reduced by 90% (otherwise, it was thousands of little, tiny, line segments).
Greg
Old 01-29-2009, 10:16 AM
I am using Gibbs. I have been using smoothed line segments out of habit due to our other CNC equipment and have been kicking around switching to arcs ect.. because of the issue you mentioned.
need some help figuring out some tool paths tnik Surfcam 3 12-14-2006 07:18 AM
Rotary tool paths DAB_Design Mastercam 1 03-31-2005 02:27 PM
3d tool paths ginamc OneCNC 5 03-19-2005 12:17 PM
xp custom tool paths Mortek OneCNC 20 06-29-2003 06:28 AM
Tool Paths WOODKNACK G-Code Programing 7 04-26-2003 09:09 PM
