On our VF-2ss, the coolant drain will clog with chips, create a swimming pool, and starve the pump. I did a brief search on this forum for this and found a rotating sweep thing that kept the drain holes clear using the auger to power it. Pretty cool. But I was wondering if anybody has tried drilling holes in the auger pan above the coolant pan. My thinking is that the auger itself would keep the holes clear. Has anybody tried this? |
| Just get the chip sweeper. $175 will pay for itself quickly. Especially if you have to put a dollar in a jar everytime you cuss. |
| The new haas machines have the holes drilled in the auger and we have problems with the chips getting in to the coolant tank the auger pushes them through the holes. we ended up welding all the holes shut and drilling bigger holes to the front of the chip auger and installed a dryer vent over them facing towards the auger and put a screen over the opening and works great. |
| My VF3 that I bought used, has about 17 rows with 8 or 9 drain holes per row. I have no idea if this was the original pattern or not. When I notice a lake forming, I run the chip auger for a few seconds. This is likely necessary anyways, otherwise the lake will form on the other side of the machine eventually. I think you can program the auger to run, but I have never resorted to that yet. Yes, chips do get through to the first stage catch basin in the chip pan. I use a piece of window screen (doubled over) to keep most of the chips from washing through the slots in the basin. Only the really fine stuff gets through and settles out in the main reservoir.
| X4 coolant | GTC | Syil Products | 12 | 08-07-2010 09:05 AM |
| Problem- COOLANT | littlerob | Haas Mills | 19 | 11-04-2008 10:11 PM |
| Question on Draining my Coolant! | SpeedsCustom | Benchtop Machines | 7 | 12-05-2007 02:12 AM |
| Coolant or No Coolant when turning.... | Crashmaster | General Metalwork Discussion | 3 | 05-20-2007 02:20 AM |
| COOLANT (what are you using?) | carbidecraters | General Metalwork Discussion | 12 | 01-22-2006 01:31 AM |
