Old 01-22-2009, 02:18 PM
jwknow is on a distinguished road
Cutting slots at various Z depths ??
Is there a way to program a Haas using a canned cycle or a sub program to cut straight line slots using various depths on the Z axis. I occasionally need to cut slots about 1 inch deep through a plate and can't find a way to program these at various Z depths without programming line by line.
All I want to do is start at a predrilled hole, feed down -.250 and make an X axis cut, rapid up, go back to the predrilled hole, feed down to -.500, X axis cut, etc. until I'm at Z-1.00.
I can do circular interpolation with a canned cycle and use varying Z depths but can't find a way to do straight line cuts at varying Z depths. Am I missing something simple here?
Thanks for any info
JW
Old 01-22-2009, 03:02 PM
djr76's Avatar
djr76 is on a distinguished road
You can use a local subroutine
Position X Y (hole position)
position your Z
M97 P1
G00 Z (2nd depth)
M97 P1
G00 Z (3rd depth)
M97 P1
and so on
M30
N1 G1 X(slot) F.
G00 Z.1
G00 X Y (hole position)
M99
Cutting T-Slots in Ally. Advice please ImanCarrot General Metalwork Discussion 6 12-05-2008 03:42 AM
RhinoCAM Cutting Curved Fret Slots Help Cartierusm Musical Instrument Design & Construction 10 07-28-2008 03:42 PM
Z-finish Depths jamesr Surfcam 2 12-20-2006 01:07 PM
Cutting or grind slots in carbide cutters?? coonhunter General Metalwork Discussion 10 03-05-2006 11:35 AM
Cutting at multiple depths.. looping ?? esmiller Mach Software (ArtSoft software) 9 01-31-2006 06:48 AM
