Old 01-03-2009, 08:23 PM
mls mls is offline
mls is on a distinguished road
spindle churp or squeak
I have a 2006 haas vf 3 I've had it 8 months the spindle squeaks or chips sometimes has any one else have this
thanks Mike
Old 01-03-2009, 08:52 PM
machinetoolguy is on a distinguished road
thanks Mike
If the machine is not under warranty I would say run it till it dies. In a lot of cases with Haas spindles you will hear what is called bearing cage rattle. It does not affect the part and it comes and goes. Kind of sounds like a rattlesnake on speed. LOL. If this is what you are hearing, I personally would not worry. If it is a constant sound (Meaning all the time at different speeds) you may want to have it looked into. Haas Factory Outlets have a vibration analyzer test that can tell you if the spindle is going bad. It looks at bearing vibration and other machine component vibration.
Old 01-03-2009, 09:26 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
My spindle started making a squeaking noise when the Vector Drive went on the fritz (250 hours on the machine). It was a bogus leg coming out of the Vector Drive that was causing the windings to chirp as the motor rotated.
Any 123 errors on the machine?
Greg
Old 01-03-2009, 10:02 PM
mls mls is offline
no greg I have no 123 alarms going back 4 months
thanks Mike
Old 01-03-2009, 10:42 PM
rlabonte18 is on a distinguished road
If you have through spindle coolant sometimes the rotary union on top goes bad making it sound like a spindle noise.
Old 11-23-2009, 09:49 AM
NATEDOG is on a distinguished road
I know of a shop that has a Haas VF3 with a 7500 rpm cat 50 spindle in it. He had that problem and because of issues he had with Haas on a lathe they wouldn't come and service it. We tore into the spindle and found that it had bad bearings. I am going to blueprint it and will post that information. I have since found that Haas has had many problems with their spindles. BEWARE!!!!!!!!!!!!! This almost cost this small shop bankruptcy. He had only 2 machines, both brand, new both Haas, 1 lathe 1 mill. Both machines have issues still.
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 12:11 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 06:51 PM
Phase Perfect Squeak 1ctoolfool Haas Mills 7 04-08-2008 03:37 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 03:49 PM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 11:48 PM
