It looks hollow in some areas .... I would like to machine 1 to 2 inches off the top of table .... I Don,t want to make the table weak... 800 lbs needs to sit on it .. or is there any way to take the table off and put a small sub plate on it ... I think I'm just going to break out the face mill and start cutting the table |
Ok...let's try this again. Being as it's that time of year...being of good cheer & whatnot... I'm going to make a few assumptions here (I know what assuming gets a person...) One, the workpiece is too large for the available travels... Two, you are the operator & not the owner... Three, you are an operator & not a machinist... DO NOT cut down your table!!! Don't even attempt this! There are several reasons I say this...the most obvious being that your table will be WORTHLESS after this job is finished. Your machine doesn't have long enough travels to cover every square inch of the table, so you'd just be cutting a big rectangle in the middle of your table. Not to mention your newly surfaced rectangle wouldn't have a proper finish or tolerances for perpendicularity & squareness. Your table will lose massive amounts of rigidity & will flex an inordinate amount...possibly causing it to bind during travel, due to the ballnuts on the X axis screw twisting +/- relative to the Z axis, or the carriers for the rails doing the same. Why would this even be an option you would consider??? If you need more Z clearance, why not make a custom riser you can lift your column with? |
| Please ignore his second post as he's spoiling the fun! ![]() Bah Humbug!
__________________ Keith |
| I get pissed at myself when I accidentally make a tiny mark in a table...if you want to cut 2" off of the table, you might as well save yourself the work and just give me the machine...it'll be easier for you to do, and you'll have the same result in the end, a machine you can't use (except in this case, it will be because it's mine now, not because it's been rendered useless). |
| I know of 2 people who have cut the table on Haas mills, to get more z travel, and the machines perform just fine. Haas offers the cut table, as a option on some of there machines. Call Hass, and get the prints on the table, and you can make a move from there.
__________________ HAAS VF3-5 axis trunion Mastercam X3 |
| Thanks for all the replies ... Im not worried about the machine being useless after I cut the table I am The owner and I have been making chips Since 1988 If I need a machine with a table I will buy another ... My question was On the rigidity of the table after I mill it .. I make about $600 per hour cutting these parts .. I just got this machine 8 months ago it has 200 hrs on it |
| If you make that kind of bucks, why don't you buy a VF-4? It's got more Z clearance. I'm assuming that you're talking a VM2 or 3. At that kind of profit, just buy the right machine for the job and don't risk ruining this one. One other thing: you will never sell that machine to anybody. It's value will plummet to nearly zero once you cut that table. If you can afford that, you can afford to buy the right machine. This is so far out there that I have to wonder if you're trolling us.
__________________ Greg |
This is a VM-3 I got it for a steal . I Can make due right now with out cutting the table I have some new jobs in the future that I will need a few inches of clearance.. I will make sure I video the table getting machined If i do it ... Do you think a HFO would install A riser block ? Or would I have to pay a non Haas Serviceman to do that and would I have to make a custom gord tube and extend all the wires and coolant lines ... Thanks for the tips |
#11
I would need to have one tapered and shrink fit The tool in the spindle is 6 inches long with 5 inches exposed The part is 23.5 tall Thatsdoesnt leave me much ... |
#12
| I thought the VF-4 had a higher spindle height than the VF-3 but the site says otherwise. Why not a VF-5 then? I'm pretty sure it's the same cabinet and has 4" more Z. It's good that you have this much work for it.
| How thick of metal | slvr98svt | Laser Engraving & Cutting Machines | 2 | 10-27-2008 07:58 PM |
| How thick? | lgalla | Mechanical Calculations/Engineering Design | 28 | 11-03-2007 01:23 AM |
| Making a positive mold from a negative mold - how? | SRT Mike | Moldmaking | 7 | 03-29-2007 05:30 PM |
| NEwbie Help, is this too thick for my TIG ? | Calico | Welding, Brazing, Soldering, Sealing | 19 | 09-29-2005 07:16 PM |
| How thick is too thick? | lookalion | General Metal Working Machines | 5 | 08-30-2004 03:08 AM |
