Old 12-19-2008, 11:39 PM
lkenney is on a distinguished road
Replacing rear cooling fans on older Haas VF-0
On my 1992 VF-0 the cooling fans are so loud that after awhile it get tiresome. Has anyone replaced these with newer quiter fans that equal better the cooling power. If so what did you use? I know that the new VF-2 and VF-3 that a nearby shop have are much more pleasent to work around. It is hard to talk and hear when I have the VF-0 running even when it is not cutting.
Eagle
Need Help!- Replacing a Haas Monitor Depth_of_cut Haas Mills 32 01-06-2012 12:16 PM
RFQ- Small job on a front and rear panel Dougie085 Employment Opportunity 29 04-18-2008 08:17 PM
Rear toolpost operations? zephyr9900 Mach Lathe 4 10-12-2007 05:00 PM
Adding rear shaft to MCG ID33004 avale Servo Motors and Drives 7 07-03-2007 05:00 PM
CNC machined cooling fans mroy0404 Parts for Radio Control Models 4 05-19-2007 10:06 PM
