Old 12-18-2008, 05:32 PM
fourperf is on a distinguished road
Line voltage alarm
well, I have had my vf2 for 1 year and I I had no problems. Today I had 3 line voltage alarms. I re-powered up the machine each time and all was good. I have that early power failure detention module thingy. I am hoping its just the incoming power with the funky weather we are having in socal. I am running a 30hp phase a matic rpc. My machine is just out of warranty so I am holding my breath. Any thoughts?
Mark
Old 12-19-2008, 08:14 AM
lkenney is on a distinguished road
Mark,
I used to get those a lot, but after I switched phase convertors and ran only one machine on each one they have gone away. I don't know if that helps but I would look at your power equalizing switching on the RPC to make sure it is keeping things with in 5% power flux. I burned up a FANUC control on my Takisawa lathe trying to run both my haas and lathe on one RPC. Life has been much better since I put them on seperate RPCs with good load switching. It could be as you say the funky weather affecting your power but you can ask your power company to hook up a power recorder to isolate where the trouble is. This is an area where there can be a lot of finger pointing but you need to isolate the problem quickly.
Hope things smooth out.
Eagle
Old 12-19-2008, 10:13 AM
That is why you have the Power Failure Detection Module. Without it your machine might 'coast through' a very brief blip, but it might shut down and kill you tool or job.
Your local voltage may be running a bit low making it more likely that the detector circuit will trip. When does it happen? Any time no matter whether the machine is running or not, or just when the machine is starting up or running under a heavy load.
Sometimes when the supply voltage is marginal the machine will trip out due to the starting draw pulling the line voltage down a bit. In this case it is possible to change the Parameter that controls the maximum spindle acceleration during start up.
Old 12-19-2008, 10:17 AM
thanks a lot Eagle. I have my haas on the rpc by itself and the power in within the 10% haas requires. Its is like you say within 5%. I have 240.6 over 2 legs and the third is 250.4.
Thanks for you reply.
Mark
Old 12-22-2008, 12:14 AM
machinetoolguy is on a distinguished road
The power detection module was created on Haas machinery so that when power is lost or turned off, the Z axis brake has time to engage. There is a slight delay before the brake engages. It has also however, proven to assist with brief voltage drops as Geof stated. Check and be clear of what type of alarm you are getting. If it is an overvoltage alarm you may want to get some type of surge protection.
Old 12-22-2008, 10:41 AM
Hi Geof, I didnt see this post before. It was alarming out when the tool was spinning up. It hadnt started cutting yet.
machinetoolguy - the alarm was a low voltage alarm.
thanks for the help guys.
mark
Old 12-22-2008, 12:24 PM
Parameter 196 C ACCEL LIMIT LOAD set in the factory at 195 (%). You can reduce this to whatever you want and it reduces the power draw when the spindle spins up. At 120% you hardly notice any difference on the time it takes to get to speed; at 100% it is a tiny bit slower.
Old 12-23-2008, 02:54 PM
Thanks a lot Geof. If it continues to alarm out I will try that change.
Mark
Over Voltage Alarm? UBRacing Haas Mills 6 12-02-2009 06:38 PM
fanuc OM high voltage alarm maxvic Fanuc 15 07-01-2009 12:07 AM
compressor causes voltage drop and alarm 1ctoolfool Haas Mills 6 06-01-2007 04:57 PM
SL 10 Low voltage alarm PBMW Haas Mills 4 02-03-2007 08:40 PM
1995 Haas VF4...Over Voltage alarm? jrudicel Haas Mills 1 02-02-2007 02:16 PM
