Old 12-16-2008, 01:37 PM
Knowklew is on a distinguished road
multiple TLO settings
I have a 2007 Haas MiniMill and a 4th axis HA5C. I am trying to figure out how to use multiple TLO settings with the same tool at different parts of the program.
I normally use something like this:
T1 M6
G43 H1 Z1.0 M8
and the H1 corresponds to the TLO that I set in the offsets page. How would i set multiple offsets on the same tool? would it be as simple as going:
T1 M6
G43 H11 Z1.0 M8
and therefore have the H11 spot set to the different offset?
Fred
Old 12-16-2008, 02:26 PM
Cory is on a distinguished road
T1 M6
G43 H1 Z1.0 M8
T1 M6
G43 H11 Z1.0 M8
Fred
Yes, but you will need to make sure you have H&T matching turned off.
Old 12-16-2008, 11:59 PM
automizer's Avatar
automizer is on a distinguished road
Have you thought about using a work zero shift to control the variance? I have found playing with tool lengths in the program can be dicey, just my 2 cents
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 12-17-2008, 09:42 AM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
work offests, better than tool
I agree, it's much easier and safer to use a work offset z shift to accomplish what you want. This will achieve the same result without having to turn off h and t agreement
Old 12-17-2008, 07:38 PM
EXCUSE THE SHOUTING BUT I WANT TO BE EMPHATIC DO NOT TURN OFF H & T AGREEMENT!!!!! THAT WAY LIES THE POTENTIAL FOR SERIOUS CRASHES.
Okay now I will calm down.
Easiest way is G51 Z(some value).
Set your tool offsets to a point somewhere above your highest work location then you adjust downwards by using G51 Z-nn.nnnn.
The reason i say "above your highest work location" is because then you have to use negative Z values. If you make an error and enter a positive value this means the tool stays way too high.
However if you set things up so that the Z shifts have to be positive...and make an error the tool goes way too low probably with disatrous consequences.
Need Help!- Can't get multiple passes in v3.0 Vogavt LazyCam 2 01-26-2008 04:57 PM
Multiple copies jstransky Machines running Mach Software 0 04-22-2007 04:52 AM
Multiple Positions Available -TN StacyE Employment Opportunity 0 04-19-2007 01:02 PM
Multiple Parts In M.C. stang5197 Mastercam 5 03-11-2007 08:13 PM
Multiple Parts nitemare G-Code Programing 2 12-21-2005 08:14 PM
