Old 12-11-2008, 03:12 PM
chucker's Avatar
chucker is on a distinguished road
G154 Select Work Coordinates Help
In my haas manual it shows additional work offsets P1 to P99 you use G154
P1 and so on like the G54.1 P1 on other controls Then it shows #14001-#14006 I am ussuming this is the register where you would put your X,Y,Z,A,R vaules. Now the Dumb question where do you find these registers in the control to view what is in them I am thinking you could enter the value in them like this #14001=10.6 from the program is this correct I do some thing simular on a fanuc.
Old 12-11-2008, 03:24 PM
The G154 P(whatever0 work offsets all show up on the work offset page and you enter values into them the same as any work offset; cursor down to the appropriate line and use the work zero key or type in the values and press Write or F1.
If you want to enter from the program use G10.
Old 12-11-2008, 04:23 PM
chucker's Avatar
work offsets
Geof
on my work offset page I have
G52
G54 to G59
G110 TO G129 These would could be call by G154 P1 to P20
G92
Not counting G52 and G92 thats 26 Offsets I can use I need 32 for a tomb stone
Book also shows
G154 P21 to P30
P40,P50,P60,P70,P80,P90
and P95 to P99
with what the book shows above there should be 21 more offsets I could use but these do not show on the work offset page. My mill is a was made in 1999 my book says 2004 maybe my mill is to old and does not have this option ?
Old 12-11-2008, 04:45 PM
MikeOD is on a distinguished road
I think your mill is just a good deal older than the software on your machine, so there are less work offsets available to you.
Old 12-13-2008, 03:39 AM
Originally Posted by chucker View Post
.. My mill is a was made in 1999 my book says 2004 maybe my mill is to old and does not have this option ?
Correct, too old, but have you read up on G52 or done a search here for threads discussing G52? Using G52 is an alternate method of getting an unlimited number of work offsets. Also using G10 you can change offsets from the program so again you can get many more than simply using fixed offsets.
Need Help!- Yasnac MX2 work coordinates. PHD General CNC (Mill and Lathe) Control Software (NC) 4 05-14-2009 09:47 AM
G92 coordinates monaro mike Fanuc 12 07-28-2008 08:27 AM
Newbie- Work Planes / Work Coordinates MICFDI Esprit 9 05-12-2008 12:35 AM
losing work coordinates at power off jlong58 Fanuc 13 07-27-2007 06:31 AM
Okuma Work Coordinates firedog General CNC (Mill and Lathe) Control Software (NC) 7 06-09-2005 07:43 PM
