Old 12-11-2008, 12:29 PM
chucker's Avatar
chucker is on a distinguished road
getting control to beep
I use a marco statment in my programs to count how many parts each tool has ran. Then using #3006 I send a massage to the screen to tell the operator what tool needs changed. The problem is that the operator is running other machines and some times will not notice that the machine has stoped at the #3006 massage is there a way to make the control beep in the program just before the #3006 sends the massage other than M30 M00 M02
M01.
after looking at the pallet suttle marco program I found that #1139=1 will make the buzzer for pallet change come on and #1139=0 will turn it off this will work just sa good as the control buzzer.
loud beep at every key press? turn off? pmurdock Haas Mills 9 01-14-2008 02:39 PM
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 10:57 AM
Need Help! Motors beep, then stop :( Mite E Copter Controller Cards 0 12-15-2007 10:56 AM
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 03:20 PM
beep too loud 1ctoolfool Haas Mills 4 03-26-2007 12:40 PM
