Old 12-09-2008, 05:52 PM
stovepipesteve is on a distinguished road
m30 x 3.5 tap speed?
material A36.
machine is a VF3,30 horse, gear driven. 50 taper.
tapping 2'' deep. The tap is 4 fluted.
im thinkn of starting out about 100-125rpm.
ill be holding the tap in a collet so im worried that it will slip in collet running the torque its going to require to tap 2'' deep.
any thoughts would be great.
thanks.
Old 12-09-2008, 11:29 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Edit: I'm a moron. I read the original post as a 3.0 mm tap, 3" deep, not a 30 mm. Never mind. That's a huge tap. Ram that sucker in there.
Greg
Old 12-10-2008, 12:33 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
the collet will probably slip pecking or straight tapping
your best bet is to ditch the collet holder and make a sleeve to fit the tap into a sidelock ,other than that i cant see any reason you can't tap 2" deep if its spiral flute , ive done it many times with near the same or larger dia taps to more depth , chances of breaking the tap is slim to non if it is of any quality ,
if your tapping multiple holes then i would suggest monitoring the tap in between holes and watch that your not building a bird nest around the tap because it will do damage
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 12-10-2008, 12:49 AM
Jason3's Avatar
Jason3 is on a distinguished road
Greg - you had me worried there I thought I was a bit of a small thinker for a while - wow, I thought. M30 is a small tap. He must do some BIG work!
Jason
Old 12-10-2008, 12:53 AM
Yeah, I was looking at some really small taps the other day. I read the post and wondered how sombody would push a 3.0 mm tap through 17D worth of steel.
Greg
Old 12-10-2008, 12:44 PM
Excelmachine is on a distinguished road
How about thread milling it?
Old 12-10-2008, 06:03 PM
well i went in for the kill today and ran the big M30x3.5, 4 flute, bottom tap 2 inches deep,3 times.
I used a speed of 120 and a feed of 16.5354. i flooded it with coolant and let her rip, it did awesome. Im holding it in a large collet so ill keep an eye on the holder cap loosening or slippage.
Thread milling was not an option due to cost and hard to find mill body to insert type and ive never thread mill before, i would love to master it though.
Old 03-06-2009, 01:54 PM
ttieuli is on a distinguished road
Talking Vardex thread mills
You can try Vardex thread mills. I've thread milled some pretty big threads with them. Vardex has software that will write code you can cut and paste.
It's really very easy!
Old 03-08-2009, 01:04 PM
PBMW is on a distinguished road
You could have bought two thread mills for the price of that tap....
And it would do the job nicer and faster. Not to mention lasting longer....
Old 03-08-2009, 01:37 PM
dertsap's Avatar
Gold Member
nicer ?
threadmilling will take a lot longer amount of time if there are multiple holes
ZERO SPEED, anyone know? JohnnyTurn Mori lathes 4 02-25-2009 04:10 PM
Getting a little more speed out of your cnc. newCentroidUser General CNC (Mill and Lathe) Control Software (NC) 0 03-04-2008 08:39 PM
! Speed ! Redline Xylotex 31 09-02-2006 10:19 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 04:29 AM
min speed exceeds max speed for axis "x"? ljoe1969 TurboCNC 4 01-19-2004 08:49 AM
