  #37   Ban this user!
Old 07-31-2011, 09:58 AM
Wcarmn is on a distinguished road
When you say you are using the usb stick you got with your 08 machine...you dont mean you are using the one with your parameters on it, do you?
  #38   Ban this user!
Old 08-01-2011, 06:08 AM
double a-ron is on a distinguished road
Not at all. I mean the cheap swag they give you when your going through the buying process. I also got a hat, a stainless coffee mug, and a t-shirt. The mug and thumb drive are the only things that held up over the last 3 years. In fact they've given me fewer problems then the mill has.
  #39   Ban this user!
Old 08-01-2011, 08:41 AM
Laser Motion is on a distinguished road
We have a unit and it works with any window's operating system including windows 7 and holds the memory of 100 floppys on one stick with no software setup and no problems, plug and play.
  #40   Ban this user!
Old 11-21-2011, 06:57 AM
rawbits is on a distinguished road
the missing point
Hi All!
The real problem is not that floppy is slow. Here in the lab, experiments last longer to worry about the slow floppy and you can use a computer to copy the data to your pendrive for taking home. The real solution were when you have your own pendrive, insert it to the machne, get the data and go home. Now that would be an improvement! With the device here - if I understand right - you can only use a dedicated pendrive formatted and prepared to use with the machine and after that you need to go the another computer and copy the data to my own pendrive. That is exactly the same as with the floppy...
So from my point of view is just plain eye-wash. But I definitely buy one of the product that solve my problem.
  #41   Ban this user!
Old 11-21-2011, 09:23 AM
Kwalityenterpri is on a distinguished road
Smile New version of emulator
Hi
We have a version , but frankly we have not tested on Haas. Technically speaking , it should have not problems working with Haas until and unless Haas works onnon-dos formats. It works on creating folders inm Pen Drive rather than formatting with prescribed software.
Few features:
• Cannot read /write in Non-Dos Formats
• Does not require Preformatted USB Flash Drive. Works on a folder name based concept. Means-
Data in folder 001 on USB is = 01 block on emulator
Data in folder 099 on USB is = 99 block on emulator
• Few devices require a feature of ‘Ready Signal’ of FDD . This version supports “READY SIGNAL”
• Full capacity of pen drive can be used
Costs os 65 USD + shipping . The surety what I can offer is that if it does not works the payment shall be refunded except the Shipping Charges.
Regards
Vishal
Floppy Drive
  #42   Ban this user!
Old 11-21-2011, 09:56 AM
Sounds like a plan...
So One can use any kind of pendrive with it with the lots of trash on it and any stuff not related to the drive and it isn't care about them just those folders what has the numbers 001, 002, etc. Right?
And what if the pendrive isn't have the folders or just one. Does your drive create the folders it needs by it self?
This would make it really plug and play and usable.
  #43   Ban this user!
Old 11-21-2011, 10:03 AM
New emulator
Hi
You need to creat folders by yourself. Yes, anything which is not in folders name 001 - 099 is not of concern by emulator.
We would recommend not to use Sandisc/Transcend make pen drives as we have faced few issues with them of not being recognized.
We have tested with HP/Kingston upto 8 gb.
Regards
Vishal.
Vishal
http://www.floppytousb.net
  #44   Ban this user!
Old 11-21-2011, 10:16 AM
OK then...
Ok, then I think it'll work. The machine is seems to be an old PC packaged in co with the other equipment and runs DOS with the specialized measuring program which saves the data on a 3 1/2 floppy disk in text format.
I'll ask my boss and place the order if I can convince him of the need.
Thank You!
  #45   Ban this user!
Old 11-21-2011, 10:36 AM
Shane123's Avatar
Shane123 is on a distinguished road
its nice to see when spammers set up multiple acct's to sell their wares.... teamwork, eh?
Need Help!- DNC from floppy drive jwknow Haas Mills 5 03-11-2010 08:39 AM
Retrofitting an Older Light Machines CNC Lathe brainstatic General Metal Working Machines 4 02-01-2009 07:35 PM
Floppy Drive advt001 Cincinnati CNC 4 10-11-2008 09:35 PM
Auto Stop Upgrade for older machines sharpshooter90 Shopmaster/Shoptask 1 04-01-2008 02:37 PM
TC,1 On newer controls what about the older machines.. chipsahoy Fadal 2 04-07-2006 06:59 AM
