Old 12-06-2008, 03:48 PM
slideleft is on a distinguished road
Z offsets
Can someone please explain to me why Z coordinate offsets are opposite of what I would expect them to be? e.g.; negative value for higher position, positive for lower.
Thanks,
Jeff
Old 12-06-2008, 05:23 PM
-Chris- is on a distinguished road
z offsets
Theres not enough info to answer your question. though in my shop we have several Haas machines and a multicam router, The Haas has a standard system while the router is just oposite requireing positive numbers to increase depth of cut Is it machine spacific?
Old 12-06-2008, 06:40 PM
Well,
I have 2 operations for my current part. The 1st using G54 offsets, Z offset=0. The second op is in a fixture .5" higher and using G55 offsets. My question is- Why isn't the G55 Zoffset a positive .5"? I have to input -.5" to get the proper position.
Old 12-06-2008, 07:37 PM
kendo is on a distinguished road
I think its because the offset is measured from the spindle face
The distance from the spindle face at machine zero to your G55 is .5" less than G54
Old 12-06-2008, 07:57 PM
Parameter 57, COMMON SWITCH 1 has an entry #25 called NEG WORK OFS and the description reads:
"Selects use of work offsets in negative direction"
I think this changes the sign on the entry in the Offsets Page.
Old 12-08-2008, 12:00 AM
Param 57 neg work offset
Geof,
Thanks for the info. I found the parameter but it says it is locked. How do I unlock if I want to?
Old 12-08-2008, 12:04 AM
Originally Posted by slideleft View Post
Geof,
Setting 7, turn it off then push E stop and you should be able to change the Parameter.
Old 12-08-2008, 12:53 AM
Found it Geof. Thanks.
Offsets not big enough! John3 Fanuc 19 02-07-2009 10:03 PM
H and D offsets CNCMike Fanuc 11 05-27-2008 11:33 AM
offsets help please. allmotormatt Haas Lathes 1 03-03-2008 08:36 PM
Using WC Z offsets Shotout Haas Mills 2 04-26-2007 07:06 AM
Down/up loading offsets JPann Machine Problems, Solutions , Wireless DNC, serial port 0 03-21-2004 09:17 PM
