| You need to change the fingers on the carousel. The difference between BT40 and CT40 is in the flange that is gripped by the tool changer. Actually there is also a difference in the size (height I think) of the dogs but the Haas spindle is made to accommodate either.
| In addition to what Geof pointed out, a CT holder is also longer than a BT holder. In the Haas manual, it shows it as .12" longer (2.69" vs. 2.57"). That will cause the pull stud to sit higher, but as luck would have it, a BT pull stud is .114" longer than a CT pull stud (1.104" vs. 0.990"). I'm not sure if that .006" difference is cause for concern though... Geof, are you sure that dafowfidy needs new fingers? Take a look at the attached picture (out of an NSK catalog). The V groove on both tool holders is 60° inclusive, with one of the differences being the depth of the groove. If the fingers fit into both holders, it just means that they would have to open more for the CT holder. As far as the different height from the gage line, that would mean altering the parameter that tells the Z axis where to go for a tool change. Haas charges the same for a BT machine as it does for a CT machine, which might be because they don't have to change anything mechanical. I wouldn't put it past Haas to make a one-size-fits-all spindle...goes well with their lean production methodology. |
| I could be totally crazy but didn't I read in here somewhere that the BT to CAT conversion on the umbrella tool changer involved turning the finger plate upside-down? I thought the offset was built into the fingers and installation direction determined which configuration you had.
__________________ Greg |
| Older umbrella ATC's had reversible fingers, so you could turn them over yourself, but the later ones need completely different fingers. The sidemounts only need the arm changed.
__________________ >>>>>>>>>> Made In England <<<<<<<<<< |
Does any one know off hand what and were the parameter is to change the Z Position? I am looking in the manual that came with the machine but it seems there are a few pages either missing or out of order |
#10
| If it is a CT carousel all 40 fingers will need to be replaced. They are different. You will also need to move them from on top of the dog key to the bottom. Don't forget to change parameter 64 (Tool Change Hieght) after this has been done. Pretty easy and inexpensive fix. Vise Versa for BT to CT. |
#11
It is a 92 VF2 16 station, not That one station needs new fingers so I guess I am down to 15. Anyway first thing in the morning I will look into parameter 64. Also note the dogs are currently under the fingers. |
#12
| Ok so we have a 16 station BT carousel here. If it has the old school 1 piece style finger set up it is still an easy fix. The fingers are for sure different so they will need to be replaced. The actual diameter where it grips the tool is slightly different. I have not seen one of those style setups in a long while. Sorry for the misleading info before. I used to work at the factory back in 1994 building the carousel plates. They changed to a 2 finger set up in 92 or 93. The Haas part number for the CT single finger extractor is 22-7066A and for the BT it is 20-7166 check it out with your local Haas Factory Outlet. Hope I cleared the confusion I caused. |
| osp -convert | phx | Okuma | 6 | 10-11-2011 07:55 AM |
| How to convert DXF to PLT | Kristjan | General CAM Discussion | 1 | 07-17-2007 06:08 PM |
| Can I convert this? | Crazy Phantom | Benchtop Machines | 4 | 12-13-2005 12:47 AM |
| How did you convert | CNCadmin | Benchtop Machines | 5 | 03-18-2003 10:42 AM |
