| spindle probe error It says "start up failure" and now the led blinks red, blue, green continuously for the last 30 minutes. Is this the battery? I can't make much sense of the instructions in the quick start guide, when I deflect the stylus for >5 seconds, nothing happens. We've had this thing for about 3 months now, I heard the batteries last about twice that long. Anybody know anything? Thanks Kenny |
I just had the same problem ... Change the bats but dont try to reprogram the probe That is what renishaw told me ... good luck finding the right batteries for less than 20 bucks a piece ... You can find them online for 5 bucks |
| I use the probe as little a once a day and sometimes 25 or 30 times. Your problem is dead battery's. I keep 4 or 8 in the tool cart next to the Haas. I burn through a set every 30 to 90 days and mine always crap out at 2 in the morning on a rush job |
| ebay around $4 each |
Really? Mine lasted almost a year. Granted we go through long periods of only 1-2 uses a week, and then a few weeks/month or two of using it every day, but it definitely lasted longer than the equivalent of 90 8 hour shifts. |
| if its flashing blue and reds,then its batteries. they last me bout 5-6 months. the spindle probe eats up the batteries lots faster if your using it in programs. the table probe lasts longer cause its not used as much. if you need to ,you can swap the batteries between the probes if ya need one or the other. |
| it doesn't surprise me then that my batts went dead in 3 months We run frames that get an average 16 holes around the perimeter one frame and one matching "clamp ring" on the table per run so 32 holes and each one gets probed for Z variance we get variance of .05" sometimes between holes and that would ruin the countersinks The probe stays on through the whole process which is a little under 4 minutes per run, 40 runs per day I was using the renishaw macros for everything, and they would turn the probe on and off each time it touched, but I cut the probe cycle time in half with some new macros and leaving the probe on. |
| I have a couple fixtures that get dialed in at least 4 times a week each. I have to probe xyz and then probe 8 bores... ![]() Do that plus all the one off stuff I do... ![]() ![]() ![]() ![]() you eat batteries pretty quick. I am not complaining, if the batteries are going dead it means I am working. |
| Eritex, I'm diggin that custom tool setter cover. |
#10
My first tool setting probe failed after 2 weeks. I was told by Haas to put a "cover" of some type to keep coolant off the probe. I had 3 hard shell tacos supremes that day for lunch with a Diet Pepsi. The taco wrappers didn't work so the soda got sacrificed |
#11
| Thats strange...I've never seen an OTS fail from coolant and/or chips...I HAVE seen plenty of batteries die. Just beware, the ones you get at Radio Shack...die a LOT faster than the brands Renishaw recommends in their quick start manuals that came with your machines. |
#12
| The batteries in my OMP40 probe died a couple of days ago and after freaking about not haveing any and no store in my area having any, I decided to see if maybe Mcmaster Carr would have some (they have everything else). i looked in the catalog and found a listing for 1/2 AA lithium batteries with no other information on the product. i decided to order a pair hoping that they would be a good brand and would get the probe working. when they arrived the next day, much to my surprise, they were the same brand and model that came in the probe, SAFT LS 14250. And they only cost $4.82 a piece. McMaster Carr Part #6951K59. |
| Possible solutions for #9 error besides spindle drive | carbidecraters | Fadal | 4 | 11-01-2008 01:18 PM |
| Fanuc 6T spindle error | ABT | Fanuc | 12 | 08-03-2008 09:18 PM |
| Renishaw spindle probe question: Checking concave radii for size | Matt@RFR | Haas Mills | 6 | 06-12-2008 02:24 AM |
| help!: spindle serial link error | emonje | Fanuc | 1 | 05-08-2008 11:07 PM |
| Spindle Z fault error | dapoopta | Haas Mills | 3 | 10-14-2007 08:58 PM |
