Old 11-29-2008, 07:07 PM
skullworks is on a distinguished road
Thumbs down VF-0E Z axis does Zero return towards table.
One of our VF-0E machines will start moving in the Z negative direction while seaching for home.
Complete powerdown - diconnect off for a few minutes will sometimes cure the problem, but its been getting worse.
Last Monday morning it took well over a dozen power cycles to get the machine up.
This Monday will also likely be fun.
Another problem is that a few times due to all the repeated attempts to zero the machine, the head is down almost to the table and without Zero this edition of the software does not allow any manual movement to get the head back up.
Any Ideas?
Old 11-29-2008, 07:19 PM
The zero proximity detector on the Z axis probably has a chip of metal stuck to it or it is in some other way malfunctioning.
When the axis homes it moves negative until the proximity detector is activated then it moves positive until the proximity detector goes in-active and finds its zero.
If there is a chip or something on the detector it never goes inactive so the axis just keeps moving positive.
You probably can move it without zero. Go into Settings and turn ON Setting 53 JOG W/O ZERO RETURN. Be careful doing this now you can run the axis into the hard stops if you get carried away.
Old 11-29-2008, 07:53 PM
Thanks Geof:
I bet your spot on as this machine has also had some recent issues with the Z axis way covers.
New Machine Build- Three Axis CNC from Table Saw jhowelb DIY-CNC Router Table Machines 51 03-03-2009 05:56 PM
4th axis on PCNC table BallisticFab CNC Plasma and Waterjet Machines 3 11-01-2008 08:37 AM
Fanuc 4th axis zero return question drgbt Fanuc 5 01-17-2008 03:09 AM
Using X axis table moter for knee X axis imatoymaker General Metal Working Machines 1 09-10-2007 07:23 AM
Table for the Z axis? ZipSnipe General Metal Working Machines 16 03-06-2006 05:57 PM
