Old 11-20-2008, 01:22 PM
slideleft is on a distinguished road
M01 command
Hi group,
What is going on? I have some M01 commands in a current program which appeared to be working fine initially, but somehow now upon "cycle start" spindle does not come back on. Any ideas? Thanks.
Jeff
Old 11-20-2008, 01:29 PM
Originally Posted by slideleft View Post
Hi group,
Jeff
The spindle never does start automatically after M01 or M00 you need to make sure these commands are followed by a spindle start command.
Old 11-20-2008, 02:14 PM
Ah ha!
Well that would explain it. Thanks so much.
BTW, this forum subscribes to the concept that there are no dumb questions, right? Because I have a feeling I have a lot more to come. I have been reading my Haas manual, but there is not much detail.
Old 11-20-2008, 02:34 PM
....BTW, this forum subscribes to the concept that there are no dumb questions, right?...
Yup; dumb answers are another thing altogether, and I have been guilty on that side through not fully reading a question.
I am also guilty of putting in a M01 that stopped the machine just before it entered a profile cutter without the M03 to restart the spindle. When I pressed cycle start the machine simply started feeding into the cut with a stationary tool and sheared off a brand new 5/8" carbide. I watched it do it and then realised I could have hit Feedhold and started the spindle using the CCW key.
Old 11-20-2008, 03:01 PM
Originally Posted by Geof View Post
sheared off a brand new 5/8" carbide. .
Yes, mine was only a 1/8 carbide.
G03 COMMAND HELP!! hkfanatic G-Code Programing 25 08-04-2008 03:14 PM
Need Help!- Handwheel command and MPG precourt CamSoft Products 5 03-24-2008 10:14 AM
tolerances for 3d command moldmker BobCad-Cam 4 10-07-2007 04:17 PM
does it have FOPEN command? hop Fanuc 2 06-20-2006 11:10 PM
what is the same command? hop G-Code Programing 0 06-20-2006 05:24 AM
