Old 11-17-2008, 04:34 PM
rrbmachining's Avatar
rrbmachining is on a distinguished road
Haas VF2 Air Supply
I have just taken in a VF2 and a compressor which has turned out to be a real dog and wont hold compression. So I have had to power up the haas with no air supply and as such I cant clear alarm 108. The question is does this prevent the machine from homing as I have had no movement yet or is there another problem
Richard
RRb Machining Services
Old 11-17-2008, 04:38 PM
When the Alarm is active the servos do not have power.
I think if you hit Reset to cancel the alarm then hit Auto Restart the machine will start homing. BUT DON'T DO THIS!!!!! At the end of the homing sequence it runs the toolchanger so you will finish up with a tool changer alarm and the machine stopped with the shuttle in. (I think)
Old 11-17-2008, 09:06 PM
rlabonte18 is on a distinguished road
If you change param 76 (low air delay) from 1500 to something like 9999 it will give you time to home out everything adn move the axis's. do not use the power up restart just home out the axis's individually and you should be fine.
Old 11-17-2008, 10:47 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
I wouldn't risk a crash. I'd borrow a portable compressor or even hook up a portable air tank. Is it really worth crashing a tool changer, breaking a drawbar, homing switch or ruining the way covers over some compressed air?
Greg
Old 11-18-2008, 07:16 AM
Eagle View is on a distinguished road
Go rent an air compressor from a tool rental business like Home Depot.
/Eagle/
Old 11-18-2008, 08:32 PM
awesome83 is on a distinguished road
ALSO YOU NEED AIR TO GET LUBE TO YOUR SPINDLE.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
HAAS Service HAAS Repair NY NJ CT PA serviceman Product Announcements & Manufacturer News 1 01-04-2008 03:27 PM
Haas 2 haas serial comunication? CNCgr Haas Mills 3 12-22-2006 12:07 PM
Haas VF-3 servo distribution power supply failure Drkk Haas Mills 0 12-03-2006 09:48 PM
