Old 11-16-2008, 05:51 AM
TeeGate is on a distinguished road
Turning off beeping at tool change
Does anyone know how to turn off the beeping when the tool changer is in operation? On one of the Haas we have it moves along quite quickly so the beeping is minimal; however, one machine is much slower and the beeping is irritating. The service man tried to help us but he was unsuccessful.
Thanks for any help!
Guy
Old 11-16-2008, 08:01 PM
slideleft is on a distinguished road
Hi Guy,
I'm not trying to be a jerk, but I found the Haas beeper too loud even at the quiet setting. I popped open the panel and removed it. I have not missed it.
Jeff
Old 11-16-2008, 08:13 PM
DRD DRD is offline
DRD is on a distinguished road
I put a piece of duct tape over mine, the beep is pretty low now. Darn loud from the factory.
HAAS VF3-5 axis trunion
Mastercam X3
Old 11-16-2008, 08:37 PM
Matt@RFR is on a distinguished road
I don't know about older machines, but my '07 VF-2ss doesn't beep at all during tool changes because it's not supposed to. Questions:
-Do you have a spindle probe?
-If yes, does the beeping only happen when changing the probe in/out of the spindle?
-If yes, you need to spin the probe off after using it.
Who knows, maybe mine is supposed to beep but doesn't.
Old 11-16-2008, 09:19 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
He didn't specify but I'll bet it's a toolroom mill. The beeping is the 'get out of the way' message to the operator. Enclosed machines don't need it because you can't get your hand in the way (unless you override the door hold setting).
Greg
Old 11-16-2008, 10:09 PM
Gotcha. Thanks for correcting me Greg. Don't ever do it again.
Old 11-17-2008, 12:01 AM
I didn't think I corrected you...just added to it.
My TL-1 will drive you nuts on the tool changes (same thing: beep-beep, beep-beep, beep-beep).
Old 11-17-2008, 05:48 PM
Greg,
Yes, it is a toolroom mill and is not enclosed. However, our enclosed Super Mini Mill also beeps but because it moves so fast the beep is negligible. The toolroom is much slower and the beeping continues much longer.
I was hoping for a code to stop it.
Guy
Old 11-17-2008, 06:52 PM
Guy
Have you gone through the Settings and Parameters looking for 'Beep on tool change' or something like that?
I have several SuperMinis and Minis and none of them beep during a toolchange; I can't remember if the TM3-P beeps or not.
Old 11-20-2008, 06:47 PM
Thank you for all the posts.
We solved the problem by unscrewing the beeper and pushing it into the unit. We then taped over the hole and now the sound is loud enough that the operator can hear, and nobody else has to.
Guy
Old 11-23-2008, 12:40 PM
*Registered User*
chuckgolden is on a distinguished road
beeping
Change parameter 601 to a zero and that should take care of the beeping,
  #12   Ban this user!
Old 11-23-2008, 12:42 PM
I will give it a try tomorrow and get back to you. Thanks.
Guy
Problem- Beeping VF-2 MDISolutions Haas Mills 10 08-18-2011 04:35 PM
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 12:20 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
how to change the passes in turning joachim FeatureCAM CAD/CAM 0 02-17-2006 12:26 PM
Beeping noise dgaston Mastercam 14 09-15-2003 01:49 PM
