Ok, this is a test anyone can do easily. Using the same 3/16" endmill feed at 5000rpm 50ipm at .005" depth in aluminum. one cut is a straight line in X with one dead stop in the middle. one cut is a straight line in Y with one dead stop in the middle. The x direction cut mark(s) where the tool stops is easily removed with a scotch brite pad to be invisible to the naked eye. The Y direction cut cannot be easily "scotch brited" away and resembles the "coining" that Mr. Flat is complaining about. Approximately .0001" depth marks. Why don't these cuts produce identical results? |
| I guess it would be possible to experiment with different masses bolted to the table. Do a cut with something clamped directly to the table, then load the table to its maximum capacity and do a cut; I would expect to see some difference.
| Hi 1ctoolfool I'm surprised the coining/marks left by the cutter are not greater as if you check the X-Y & Z axes you will have .001 to .0015 slop in the linear rails this is one of the problems on these Haas machines which give you not such a good finish on your work everything is moving a round while cutting
__________________ Mactec54 |
| In 13.14 series software Haas added Setting 191 Default Smoothness to the settings page of the control which allows you to control the machines acceleration rates, which allows you to control the smoothness of the part, so by selecting FINISH on this setting you will eliminate the coining marks. I have attached a more detailed description for you to read. If your machine software is below 13.14 series, then you should contact me directly and I can change some parameters on your machine to eliminate the coining. Thank You, Gerard Bailey Applications Engineer Haas Automation Inc Tel. 800 331 6746 x7128 Fax. 805 278 1803 gbailey@haascnc.com |
#11
| Does the smoothness setting just change the acceleration or does it take the motion control down to the next level, known as jerk? http://math.ucr.edu/home/baez/physics/General/jerk.html |
#12
I'm not sure if you're aware, but inside of Renishaw probing software, about a year ago we found that if setting 191 was set to smooth, it could occassionally break a probe stylus on a Z surface measurement. As a result, G187 P1 was added to the Renishaw code (it was added in RENIPS.V25 or V26...I can't remember which), followed by G187 without a P after the probe has finished running. When making parameter changes to make a machine without setting 191 behave like a machine with newer software set to smooth, you might want to verify if the machine in question has probes or not as it could introduce a risk for damage to the probe stylus. |
| Surface Finish | life3970 | Mini Lathe | 2 | 11-07-2007 12:00 PM |
| Surface finish | skmetal7 | Mini Lathe | 7 | 09-10-2007 12:56 PM |
| Surface finish | chakaloso | General Metal Working Machines | 0 | 06-12-2007 08:54 PM |
| surface finish | fadalman | BobCad-Cam | 2 | 03-03-2007 01:30 AM |
| Surface finish | d.a.v.e | Mechanical Calculations/Engineering Design | 1 | 11-10-2006 01:35 PM |
