Old 11-08-2008, 05:32 PM
lkenney is on a distinguished road
Unhappy X-Axis VF-0 Brush Motor
Same machine, I am not getting anywhere fast. I have all the wires connected as near as I can tell but now I am getting a X follow Error Alarm 103 during the normal startup. I have the motor out of the housing but sitting on the rails/
You can follow the error codes in the earlier requests for help.
We started with a 139 alarm, then a couple of 161 alarms and onw this.
I need to get this machine running this weekend.
Thank you
Eagle
Old 11-08-2008, 05:58 PM
Did you replace the brushes?
The Following Error alarm happens when the ballscrew does not move as fast as the controller is expecting it to move. The way I understand it is that the controller supplies a certain voltage to the motor so it 'knows' how fast the screw should be rotating. If it does not detect an encoder count that matches the expected speed, within limits, then it alarms out with the following error.
If the brushes are badly worn, or sticking in their holders, they may not be making good contact so the motor may be running slow.
Old 11-08-2008, 06:34 PM
Geof
Thank you, right now I don't have the motor attached to the ball screw at all. It is sitting croswise on the rails. I am going back though the wiring changes that I made to make sure they are all correct, 1 more time.
Eagle/lkenney
Old 11-08-2008, 06:49 PM
Al_The_Man's Avatar
What you could do is disconnect the motor armature feed or connector, not the encoder.
If you power up, you should not get a following error, as long as you do not command a move.
With the armature disconnected you should be able to move the motor shaft slowly, and at some point you will reach a following error, If you get an error right away, it is most likely an encoder wiring fault.
If you re-connect the motor and get the FE on a move, if it is an encoder mis-connection the motor will probably jump and FE error out.
Old 11-11-2008, 08:04 AM
cncmaintenance's Avatar
cncmaintenance is on a distinguished road
Following Error
The Errors you are reporting all are indicating the Encoder is not indicating the motor is turning. Either the motor is not turning or the Encoder is not working.
Check the Motor Brushes.
You may be able to swap motor/encoders from another axis to help troubleshoot.
SRW
Old 11-12-2008, 11:32 PM
Eagle View is on a distinguished road
Smile
Thanks again for the help. It was a ground short(Alarm 161) in the wire can and then a broken power line(Alarm 103) to the motor. It is always the simple things that are hard to find.
Eagle
Need Help!- Need X-Axis cable breakout diagram VF-0 Brush Motor lkenney Haas Mills 3 11-08-2008 06:48 AM
replacement motor for PML&Kollmorgen DC Brush Servo Motor fymroger Product Announcements & Manufacturer News 2 10-24-2008 03:36 AM
Need Help!- Need controller for small DC brush motor tirebiter General Electronics Discussion 8 04-10-2008 04:53 AM
Router motor brush problem buscht WoodWorking 3 04-14-2006 07:34 AM
Brush Servo Motor Sources? bsc52001 DIY-CNC Router Table Machines 4 05-19-2004 09:40 AM
