HI guys, I am wondering, I have chips seriously stuck to the table on my VMC, any time I need to move vices it's out with the putty knife and scotch brite. I use the swiss coolant, and have alot of tramp oil in the tank, I read about 9 with the refracto. Any help would be nice, thanks Robert |
| I don't know which coolant you're talking about but that ain't right. I'm running Vasco 1000 and distilled water. The machine is cleaner after a run than when I started. It's 4 years old and I only run it a few times a month. No sticky residue, no clumps of chips, no smells, no complaints (well...one complaint...it makes my hands itch if I spend much time soaking in it).
__________________ Greg |
| The coolant is Blaser swiss lube, the mill is the primary mill in the shop IE it runs all day. It's weird because I don't go through alot of way lube, but there is alot of tramp oil, I guess just get a skimmer for that, but the chips sticking bugs me, Thanks |
| Blaser Swisslube is a brand (I don't think there is a specific coolant with that name). Blaser makes my Vasco 1000. You need to find out which of their coolants you actually have in the machine. Your best bet would be to call them directly. They were very helpful when I talked to them at Westec.
| The coolant we use, not Blaser, does the same thing. Methanol, (methyl hydrate) you can buy at The Home Depot should soften it fairly quickly so you can wipe things off.
. I am assuming you do not put the methanol in the with the coolant and use it just to clean up. I would like to find a solution to the stickiness it gives me kind of an eiree feeling.Greg it is Blasocut 2000 |
| We just have spray bottles around the shop to spray on and wipe off. Getting methanol in the coolant is no big deal, it simply acts as a defoamer but evaporates away very rapidly. The following is based on my experience with our coolant and the Blaser guy I had round when I was considering switching said Blaser would not be much different. The residue occurs because the water evaporates away from the film of coolant on everything leaving behind the oil portion. Plain water, hot or cold, or coolant spray does not rapidly re-dissolve the residue; it will re-dissolve slowly and if you spray the inside of the machine down with coolant before shutting it down over a period of many days eventually all the noticeable residue wil be gone. You can of course spray things down with plain water and eventually you will wash off all the residue and start finding rust spots on everything. This coolant residue is your friend because it forms a protective film on bare metal.
| methanol works really well but I find if you don't let it get that point its much simpler. If you keep the concentration right it keeps it cleaner. It sounds to me like you have it thick, if you keep it thinner your more likely to clean the machine while its running. These clumps you have seem odd if the machine is running all day, are you in a place that promotes water evaporation? I work in a shop with a shop wide mist collector and loss of water from the coolant is pretty high. I end up adding more water then I do new coolant. Just a thought for you
__________________ I'm not lazy..., I'm efficient! HAAS GR-408 |
#10
#11
In my experience 8% is on the low side. Some people run at 5% as recommended by the coolant manufacturer but this can allow rust spots to develop because the oily residue left behind when the water evaporates is too thin. I run at 10% or sometimes higher. whic also helps with tapping anyway..
| Can anyone tell me about this coolant? | alexccmeister | General Metalwork Discussion | 10 | 10-15-2008 04:49 AM |
| Air or coolant? | zedzero | Haas Mills | 13 | 03-23-2008 11:47 AM |
| What to do about coolant? | petriej | General Metal Working Machines | 6 | 09-29-2007 07:11 PM |
| Coolant or No Coolant when turning.... | Crashmaster | General Metalwork Discussion | 3 | 05-20-2007 01:20 AM |
| COOLANT (what are you using?) | carbidecraters | General Metalwork Discussion | 12 | 01-22-2006 12:31 AM |
