Old 10-31-2008, 01:29 PM
PROCEL is on a distinguished road
HAAS BEEPER
Hi all,
I'm new to the list and I have an problem with my ,93 VF4 .
The key board stopped giving "beep" feed back and the beeper doesn't work at all.
Things we have tried are:
1. Checked for speaker opperation.....works.
2. New keyboard interface board........no change.
3. New video board .........................no change.
The tech support guys at Haas have done their best over the phone but have yet to solve the problem.
Other seemingly unrelated recent problems have been a failed low voltage power supply (twice) and it also seems that the video display may be slightly squashed in the "y" direction (up and down) but it's hard to tell.
Any ideas of what to check next?
THANKS,
JAY
Old 11-01-2008, 10:28 PM
Tarkus is on a distinguished road
Did you guys try and see if the buzzer is hooped? It's just a peizo tweeter if I recall correctly and doesn't cost much money, chances are, the soldering came off the peizo plate.
http://smackaay.com
Visit my site
Old 11-03-2008, 06:24 AM
BEEPER OK
Thanks,
It's not a beeper but actually a speaker and it tests out fine.
Thanks for your help.
JAY
Old 11-03-2008, 08:15 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
How do you know it's a speaker? That doesn't sound right to me. I don't know why they'd bother to put an oscillator on their board, just to generate a single tone when they could just drive a beeper with DC. I'd bet it's a beeper that's stopped 'beeping' and now it just pops when you put DC to it (behaving like a speaker).
If I'm wrong, I'll have to chalk that one up to "ya learn something every day."
Greg
Old 11-03-2008, 09:03 AM
SPEAKER
GREG,
I'm calling it a speaker because it looks like a speaker , 2" or 3" in dia. paper with metal frame .We tested it with a 1.5 volt bat. across the speaker connections and got sounds so we know it can produce noise.
thanks,
JAY
Old 11-03-2008, 10:28 AM
Well, that sure sounds like a speaker. The later model ones all have a black plastic beeper. OK, I'm outta' suggestions
Greg
Old 03-04-2011, 02:12 PM
lightning0621 is on a distinguished road
I am having a related problem with my VF0-E. I want my beeper to be louder. The volume is maxed out. The speaker is fine and the line voltage seem correct. Any sugestions
Old 03-08-2011, 05:08 PM
Wizzard of H is on a distinguished road
want loder beeper
The beeper volume is controlled by a small pot (potentiometer) mounted on the circuit board behind the keypad. On newer systems, the beeper has a hand rotated plastic mute at the bottom of the pendant.
Old 03-08-2011, 07:30 PM
beeper
Thanks for the reply. I have already turned it up all the way. I have tried many things with no solution. So, I am simply going to add an amplifier to the speaker system. It will have an external volume adjustment. This allows the operator the ability to control the volume as needed. It seems like a good solution for my problem
Old 03-08-2011, 10:40 PM
spy008 is on a distinguished road
The beeper was really annoying so I disabled it.
Need Haas VF-4SS nemco Haas Mills 0 09-13-2008 09:09 AM
Haas tl2 Psmurf16 Haas Lathes 0 09-08-2008 07:59 PM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
HAAS Service HAAS Repair NY NJ CT PA serviceman Product Announcements & Manufacturer News 1 01-04-2008 03:27 PM
Haas 2 haas serial comunication? CNCgr Haas Mills 3 12-22-2006 12:07 PM
