Old 10-18-2008, 02:25 PM
mniadna is on a distinguished road
Processor Board
I bought a new Processor Board for my 1997 VF-O. Has anyone replaced this themselves? I swapped the board out and tried to start the machine, but I only got a screen stating memory and processor detection. Does the control software need to be added to the battery backed up memory, or does it get burned into the EPROM?
Old 10-18-2008, 04:26 PM
M_D M_D is offline
M_D is on a distinguished road
I was around when someone replaced processor boards for me. I didn't have the time to completely follow along, so I can't tell you every step and detail required to finish the job. I do know that that you will need to follow a certain proceedure to be sucessful, and without documentation or some sort of detailed explaination to follow it might be very difficult to finish the job. You will also have to re-enter all of the parameters and settings. Hopefully you have either a written copy of those and/or an electronic file backup copy, as that will save a lot of time entering them manually. If the machine has ever had any settings and parameters changed because of options being added or enabled after leaving the factory, or certain parts being replaced (e.g. spindle replacment, encorder, etc.), the original parameters may not be correct and so those will likely need to be adjusted accordingly.
I thought the replacement boards we got had instruction sheets with them, but I am not sure. Hopefully, if you don't already have them you can obtain instructions from someone or someplace. A web search may turn up something. There are possible complications, as a replacement board may not be exactly the same as original. Although it may work on the machine fine, it may need a different software version for example. The guy that did my work is a Haas service tech who is quite sharp about electronics the control function, and he had the factory on the phone a few times.
Sorry I can't tell you everything you will need to know to finish the job. Hopefully you will get it completed without too much more hassle or expense, although getting someone who actually knows the ropes may be best.
Old 10-20-2008, 07:31 AM
I know this... I already have a recent backup of my parameters and settings on the PC that I have connected to the machine. Board did not come with instructions. My board is an upgraded part number with a co-processor and extended memory. It is the correct board for my machine and will run the 9.xx versions of the software. I just need to know how to get the software from one board to the other. Since I have already paid for the software in on the original board, I should be able to move it myself. Without paying a "service man", that has to call Haas to find out how to do it. I couldn't find anything on the web about this.
Old 10-20-2008, 09:17 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
There is a command line prompt in the Haas control. It's a computer, just like any other. It has cryptic commands (think DOS or Unix) that you won't be able to look up. You're basically 'reloading' your old information to a new computer.
I'm afraid that unless somebody here knows how to get into that mode and move the necessary information, you're going to be stuck getting a Haas tech out there. The machine doesn't have its basic information 'burned' into the board.
Greg
Old 10-20-2008, 09:45 AM
Yeah, when I ran the machine with the new board. It was like a PC that didn't have a HD. It had a command line prompt, but no drive letter. I tired using Dos commands, but none of them worked. I didn't try any Unix commands, though. My old board just boots to the control software. I mailed Haas to see if they will tell me what to do. I have a 1999 service manual, but it only covers replacing the hardware. Anyone have a newer service manual?
Old 10-20-2008, 01:36 PM
Haas_Apps is on a distinguished road
Need Software Installed
You will need to have the software installed. This can only be done by a service engineer.
Sorry I can not be of more help. The process can get complicated.
Old 10-22-2008, 08:05 PM
Moxo is on a distinguished road
You need Software to program the Processor Board, Parameters,setings,etc.... backup...
Please call Haas for service. It´s very easy to do that.
1997 VF-O Processor Board??? mniadna Haas Mills 0 09-24-2008 12:46 PM
How to connect ELM Board and OSMC Board ? bigeye3107 Open Source Controller Boards 2 06-16-2008 06:26 AM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Processor board errors Vern Smith Haas Mills 0 04-17-2007 09:34 AM
Can I hook up a 3-axis board to a 1-axis board ? Redline Xylotex 7 02-09-2007 09:45 PM
