I have a Haas Mini Mill built in Feb 2006. There are two serial ports on my machine. The top serial port is plugged into the I/O board (middle board). The bottom port is plugged into the memory board. I'm currently using the top serial port to backup and restore my programs. I have 8mb of active programs, each about 700kb in size - it takes about 20 minutes to back them up via serial port, but it took 14 hours to restore after deleting all programs. Does anyone know what the difference is between the two ports? Does anyone know why reloading my programs (8mb) took 14 hours when the backup only took 20 minutes? Same settings. What about DNC? I have a lot of small steps - i havn't tried DNC, but is the serial port fast enough? thanks! |
| Sound pretty strange to me. Are the reloaded programs correct, or have you checked the data for errors yet? I would carefully check the comm parameters. It is possible to download fast to a PC because the PC may receive without error checking. So perhaps when uploading to the control, some error checking function is detecting a lot of noise or something, and thus slowing the transmission.
| 081003-1910 EST USA xiondavis: In both directions you can transfer about 600,000 bytes per minute at 115.2 kbaud. If you use XMODEM for transfer there is error detection and correction. If you use parity check, then any error will cause the prograqm to halt transfer and you have to start over. If you do not use parity or XMODEM, then there is no error checking except for some program syntax checking, something that HAAS can not understand. Your PC program and delays in it are your probable problem. Without any handshake there are times when I can send a large file to HAAS without error at 115.2 kbaud. HAAS should not be the normal cause of slow transfer. . |
| USB ports on New Mills | elaganis | Haas Mills | 11 | 10-26-2008 09:17 AM |
| More on ports and pins | andrewbishop66 | Mach Software (ArtSoft software) | 2 | 03-08-2007 07:05 PM |
| SPC Ports What are your Use? | SMW Precision | Calibration & Measurement | 1 | 07-31-2006 03:46 PM |
| ports and pins | planescott | Stepper Motors and Drives | 5 | 03-24-2006 11:57 PM |
| Serial Ports over Ethernet | cely | Computers and Networking | 0 | 12-24-2003 12:19 PM |
