Old 09-29-2008, 06:33 AM
kendo is on a distinguished road
multiple offset probing
Is there a way to set multiple offsets with a single probe cycle?
I need to probe the center of a part and set offsets G154 P1 - P16 the same value
Do I have to call a macro that sets P1 - P16 to the same thing G54 is set to?
Old 09-29-2008, 06:59 AM
Matt@RFR is on a distinguished road
I don't have your answer but I'm curious, why do you want more than one work offset in the same spot?
Old 09-29-2008, 08:12 AM
One way to do it is move the machine to the G54 location; i.e. type G54 G00 X0. Y0. in MDI and press cycle start. Then go to the offset page, cursor down to the the lines you need and press part zero set.
Old 09-29-2008, 11:31 AM
Im trying to accurately countersink 16 holes in a frame thats been bent, welded, warped, sanded, and stacked on top of another frame and clamped together on the router table.
The z variance at each hole location can be as much as .04"
so I'm going to probe each hole and assign its Z value to G154 P1 - P16.
Each of the offsets however, need to have the same X,Y center location,
which is found for each frame by probing the center in X and Y first.
The X Y size of our frames can vary by as mush as .06, so I need to keep the hole pattern centered, and the countersink depth uniform.
We've been countersinking these frames by hand all along and even though probing 16 different Z offsets is time consuming, Its still going to be faster than the old way.
I wrote a macro that sets these X,Y offsets for me that looks like this:
I call it right after the X and Y have been found and saved to G54
O9111 (SETS G154 P1- P16 SAME AS G54)
#14001=#5221
#14002=#5222
#14021=#5221
#14022=#5222
#14041=#5221
#14042=#5222
#14061=#5221
#14062=#5222
#14081=#5221
#14082=#5222
#14101=#5221
#14102=#5222
#14121=#5221
#14122=#5222
#14141=#5221
#14142=#5222
#14161=#5221
#14162=#5222
#14181=#5221
#14182=#5222
#14201=#5221
#14202=#5222
#14221=#5221
#14222=#5222
#14241=#5221
#14242=#5222
#14261=#5221
#14262=#5222
#14281=#5221
#14282=#5222
#14301=#5221
#14302=#5222
M99
Old 10-15-2008, 11:01 AM
PaintItBlue is on a distinguished road
see if this may help....
i can explain anything you don;t understand
this part of my program goes thru and assigns a known safe xyz offset for each area that work will be done at.
In your frames example:
"The X Y size of our frames can vary by as mush as .06, " if you know you always have a Y axis offset of -8.0 +/- .03 (.06/2) you can set all of your #14xxx positions with a G10 L20 Px G90 X-##### Y-8.0000 Z-#### . This can also be used for known safe X and Z coords.
You may also be able to use the #605 parts of this program if you have different size frames . I change my # 605 at begining of program depending on what part i am running. The value in #605 then assigns #616 (hiegth) for probing
g65 p9023 Z#618 Y#617 S#803 command line
:#618=#616/2+.100(rapid space)+.118(half stylus orb)
Also depending on #605's value it assign the proper Diam (#617). Finally, with a loop counter that ties into fixture position : (#802=#802+1) (#803=#802+110) this is used for the G110-G120 (same as g154.1-g154.20)work positions.
note:#800=work cycle, #801=master work limit, #802 = operation cycle position
N800 (<<<<<JOB SETUP / PROBING>>>>>)
G65 P807 (SETUP MATH SUB)
M01 (CHECK SETUP & PROBE VARS)
G65 P802 E#803 H1. S0 T1. X0 Y0 Z1.5
G65 P801 E#803
N809 M01 (PROBING DONE >> DRILLING)
>probing math and logic sub::
O00807 (RB, TPI,NOMINAL, PROBE MATH)
G103 P1
N80700 (<<<TPI,MM TO LEAD:#609 FLAG FINE/COARSE:#608>>>)
IF [ #601 GE 6.0 ] GOTO80701
IF [ #601 LT 5.9 ] GOTO80702
N80701 (TPI TO SAE LEAD:#609, FLAG FINE/COARSE:#608)
#609= 1 / #601
IF [ #609 LE 0.05 ] THEN #608= 1.0
IF [ #609 GT 0.05 ] THEN #608= 2.0
GOTO80710
N80702 (MM TO SAE LEAD:#609 FLAG FINE/COARSE:#608)
#609= #601 * 0.0393701
IF [ #609 LE 0.0395 ] THEN #608= 1.0
IF [ #609 GT 0.049 ] THEN #608= 2.0
GOTO80710
N80710 (<<<<SET BLANK DIAM:#617>>>>)
N80711 (SET RB DIAM #617)
IF [ #605 EQ 2.0 ] THEN #617= 1.375
IF [ #605 EQ 3.0 ] THEN #617= 1.75
IF [ #605 EQ 4.0 ] OR [ #605 EQ 4.5 ] THEN #617= 2.187
IF [ #605 EQ 5.0 ] OR [ #605 EQ 5.5 ] THEN #617= 2.5
IF [ #605 EQ 6.0 ] OR [ #605 EQ 6.5 ] THEN #617= 3.25
IF [ #605 EQ 7.0 ] OR [ #605 EQ 7.5 ] THEN #617= 3.750
IF [ #605 EQ 8.0 ] OR [ #605 EQ 8.5 ] THEN #617= 4.5
IF [ #605 EQ 9.0 ] OR [ #605 EQ 9.5 ] THEN #617= 5.00
IF [ #605 EQ 10.0 ] OR [ #605 EQ 10.5 ] THEN #617= 5.500
IF [ #605 EQ 11.0 ] OR [ #605 EQ 11.5 ] THEN #617= 6.375
IF [ #605 EQ 12.0 ] OR [ #605 EQ 12.5 ] THEN #617= 7.25
N80712 (SET OD LAP DIAM #617)
IF [ #605 EQ 21. ] THEN #617= 0.750
IF [ #605 EQ 22. ] THEN #617= 1.125
IF [ #605 EQ 23. ] THEN #617= 1.75
IF [ #605 EQ 24. ] THEN #617= 3.00
IF [ #605 EQ 25. ] THEN #617= 3.5
N80720 (<<<<SET BLANK HEIGHT:#616>>>>)
N80721 (SET RB HEGHT #616)
IF [ #605 EQ 2.0 ] THEN #616= 0.360
IF [ #605 EQ 3.0 ] THEN #616= 0.450
IF [ #605 EQ 4.0 ] THEN #616= 0.580
IF [ #605 EQ 4.5 ] THEN #616= 0.765
IF [ #605 EQ 5.0 ] THEN #616= 0.710
IF [ #605 EQ 5.5 ] THEN #616= 0.938
IF [ #605 EQ 6.0 ] THEN #616= 0.770
IF [ #605 EQ 6.5 ] THEN #616= 1.125
IF [ #605 EQ 7.0 ] THEN #616= 0.833
IF [ #605 EQ 7.5 ] THEN #616= 1.250
IF [ #605 EQ 8.0 ] THEN #616= 0.875
IF [ #605 EQ 8.5 ] THEN #616= 1.313
IF [ #605 EQ 9.0 ] THEN #616= 0.875
IF [ #605 EQ 9.5 ] THEN #616= 1.375
IF [ #605 EQ 10.0 ] THEN #616= 0.938
IF [ #605 EQ 10.5 ] THEN #616= 1.438
IF [ #605 EQ 11.0 ] THEN #616= 0.938
IF [ #605 EQ 11.5 ] THEN #616= 1.5
IF [ #605 EQ 12.0 ] THEN #616= 1.
IF [ #605 EQ 12.5 ] THEN #616= 1.5
N80722 (SET OD LAP HEIGHT:#616)
IF [ #605 EQ 21. ] THEN #616= 0.133
IF [ #605 EQ 22. ] THEN #616= 0.187
IF [ #605 EQ 23. ] THEN #616= 0.450
IF [ #605 EQ 24. ] THEN #616= 0.562
IF [ #605 EQ 25. ] THEN #616= 0.562
N80730 (<<<<SET #619 X MOVE FOR Z PROBING)
(#619=MAX NOMINAL/2 +.05)
N80731 (SET RB X MOVE #619)
IF [ #605 EQ 2.0 ] THEN #619= 0.232
IF [ #605 EQ 3.0 ] THEN #619= 0.305
IF [ #605 EQ 4.0 ] OR [ #605 EQ 4.5 ] THEN #619= 0.462
IF [ #605 EQ 5.0 ] OR [ #605 EQ 5.5 ] THEN #619= 0.617
IF [ #605 EQ 6.0 ] OR [ #605 EQ 6.5 ] THEN #619= 0.805
IF [ #605 EQ 7.0 ] OR [ #605 EQ 7.5 ] THEN #619= 1.055
IF [ #605 EQ 8.0 ] OR [ #605 EQ 8.5 ] THEN #619= 1.305
IF [ #605 EQ 9.0 ] OR [ #605 EQ 9.5 ] THEN #619= 1.55
IF [ #605 EQ 10.0 ] OR [ #605 EQ 10.5 ] THEN #619= 1.8
IF [ #605 EQ 11.0 ] OR [ #605 EQ 11.5 ] THEN #619= 2.05
IF [ #605 EQ 12.0 ] OR [ #605 EQ 12.5 ] THEN #619= 2.425
N80732 (SET OD LAP X MOVE #619)
(#619=BLANK DIAM. * .25)
IF [ #605 EQ 21. ] THEN #619= 0.187
IF [ #605 EQ 22. ] THEN #619= 0.281
IF [ #605 EQ 23. ] THEN #619= 0.437
IF [ #605 EQ 24. ] THEN #619= 0.750
IF [ #605 EQ 25. ] THEN #619= 0.875
N80750 (<<<<SET #618 Z DEPTH FOR XY WEB)
#618= [ #616 / 2 ] + 0.1 + 0.118
N80760 (SET G154.XX OFFSETS:#605)
IF [ #800 EQ 0.0 ] GOTO80770
IF [ #605 EQ 2.0 ] GOTO80762
IF [ #605 EQ 3.0 ] GOTO80763
IF [ #605 EQ 4.0 ] GOTO80764
IF [ #605 EQ 5.0 ] GOTO80765
IF [ [ #605 GE 21 ] AND [ #605 LE 25 ] ] GOTO80770
IF [ [ #605 GE 22 ] AND [ #605 LE 25 ] ] GOTO80770
IF [ [ #605 GE 23 ] AND [ #605 LE 25 ] ] GOTO80770
IF [ [ #605 GE 24 ] AND [ #605 LE 25 ] ] GOTO80770
IF [ [ #605 GE 25 ] AND [ #605 LE 25 ] ] GOTO80770
N80762 (SET 2T WORK OFFSETS)
/ G10 L20 P2 G90 X-13.598 Y-8.982 Z-22.54
/ G10 L20 P3 G90 X-16.101 Y-8.982 Z-22.54
/ G10 L20 P4 G90 X-18.598 Y-8.982 Z-22.54
/ G10 L20 P5 G90 X-22.73 Y-8.982 Z-22.54
/ G10 L20 P6 G90 X-25.224 Y-8.982 Z-22.54
/ G10 L20 P7 G90 X-27.731 Y-8.982 Z-22.54
/ G10 L20 P8 G90 X-12.731 Y-6.983 Z-22.54
/ G10 L20 P9 G90 X-15.229 Y-6.983 Z-22.54
/ G10 L20 P10 G90 X-17.73 Y-6.983 Z-22.54
/ G10 L20 P11 G90 X-21.852 Y-6.983 Z-22.54
/ G10 L20 P12 G90 X-24.357 Y-6.983 Z-22.54
/ G10 L20 P13 G90 X-26.852 Y-6.983 Z-22.54
GOTO80770
N80763 (SET 3T WORK OFFSETS)
/ G10 L20 P2 G90 X-13.598 Y-9.082 Z-22.45
/ G10 L20 P3 G90 X-16.101 Y-9.082 Z-22.45
/ G10 L20 P4 G90 X-18.598 Y-9.082 Z-22.45
/ G10 L20 P5 G90 X-22.73 Y-9.082 Z-22.45
/ G10 L20 P6 G90 X-25.224 Y-9.082 Z-22.45
/ G10 L20 P7 G90 X-27.731 Y-9.082 Z-22.45
/ G10 L20 P8 G90 X-12.731 Y-7.083 Z-22.45
/ G10 L20 P9 G90 X-15.229 Y-7.083 Z-22.45
/ G10 L20 P10 G90 X-17.73 Y-7.083 Z-22.45
/ G10 L20 P11 G90 X-21.852 Y-7.083 Z-22.45
/ G10 L20 P12 G90 X-24.357 Y-7.083 Z-22.45
/ G10 L20 P13 G90 X-26.852 Y-7.083 Z-22.45
GOTO80770
N80770 (SET INIT. TC APPROACH WK OFFSET)
#803= 110 + #800
N80799 (RTM: PROBING)
G103 P0
M99
>>actual probing machine commands:::
O00801 (PROBE RING SUB - MULTI)
#802= #800 (INIT. SUB COUNTER: #800)
#803= 110 + #802
N8010 (JUDGE #802 WORK POSITION : #801 WORK QTY)
IF [ #802 GT #801 ] GOTO80199
N8015 (ACTUAL PROBING COMMANDS)
(PROBE TOP OF RING FOR Z)
G90 G#803
G00 X0 Y0
G01 Z0.1 F30.
G00 X - #619
G65 P9023 A9. S#803
G00 X0 Y0
(PROBE X Y WEB)
G65 P9023 A4. Y#617 Z - #618 S#803
G65 P9023 A4. X#617 Z - #618 S#803
G00 Z1.5
IF [#802 EQ 0.0]GOTO80199
N8016 (COUNTER sTEPPING)
#802= #802 + 1
#803= 110 + #802
GOTO8010 (GOTO JUDGE #802: #800)
N80199 (PROBING DONE >> RTM)
G91 G28 Z0
G90 M99
Old 10-15-2008, 12:57 PM
macro of your lines
sorry if the last post was a bit confusing or too much for what you are trying to do.
You can simplify your codes with this
N1000 (start g154.xx reassign to g54)
#800=14xxx (inital work x or y postion to be modified)
#801=1 (loop counter)
#802=16 (loop limitter - user edit : situational equal to X amount of holes)
#[800]=#5221
#800=#800+1
#[800]=#5222
#800=#800+19
#801=#801+1
IF [#801 GT #803]GOTO999
GOTO1000
N999 (loop done)
**Note youmay need to used a G103 P1 to limit look ahead, if the loop and reassigns are not in sync with each other.
Turn it off at the end with G103 P0
Old 10-16-2008, 03:30 PM
please, no sorry's
I love getting a look at more complex programming, I'm sure to glean some tricks from it for future use
and your last post looks like a great way to abbreviate my coding for that simple task
so thanks a bunch
with the help of this site and people like yourself, I'm learning at a pretty fast pace now on the use of macros and variables.
My main programs are looking more like macros every day
Radius Offset and Length Offset jim_stoll Dolphin CADCAM 13 10-14-2010 07:47 PM
FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! cjchands Fanuc 2 05-25-2009 11:22 AM
Probing? chunkymonkey General Metal Working Machines 2 04-01-2008 11:39 PM
Probing with Turbo CNC btalon TurboCNC 1 02-23-2008 07:19 PM
Probing geverhart WoodWorking 1 09-03-2004 02:41 PM
