| Could you tell us the exact alarm number? I don't find any reference to "Invalid R in G0". I found "Invalid R in G02 or G03". If this is the alarm, the R value may be too small. It has to be > or = 1/2 the distance between the start and end points of the arc. Another possibility is you're not getting a G0 or G1 output after a circular move. |
| I have been poking around with the machine and the MasterCam program for a while today, I noticed that all my offsets, ( G54 and TLO's ) have to be changed to get the machine to run,do you know what would cause this? I think MasterCam is doing it but I don't know why or how. thanks for any input and help. dean |
| Are you trying to do cutter compensation in the Control rather than Computer? If you're trying to cut a .25" pocket radius and the cutter radius is greater than .25, I think it coughs out that error. Make sure that the cutter radius and wear values add up to less than the arc you're trying to cut.
__________________ Greg |
| If you are using M.C. X or newer there should be a Haas post processor that will not output "R" values, it will be "I" and "J" values, I would start there, but it doesn't make sense to me why you would get invalid "R" in a rapid move? Greg I think you can stop calling yourself CNC nOOb, I give you permission, Robert |
| What I discovered is that in MCX and later, there is a setting within Mastercam that controls how it outputs Arc moves to the post. I had to tell it to break arcs every 180 degrees. That's also where you get the choice for IJ or R type arcs. The post handled both but depended on Mastercam to decide which get passed to it. This was the other thing I was going to suggest looking at, but I'd check the actual cutter radius and programmed geometry first.
| Ned Help recieving invalid port number | terry32506 | Laser Engraving & Cutting Machines | 5 | 07-17-2008 10:29 PM |
| Help! LaserCut software invalid serial port problem | terry32506 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 07-17-2008 12:21 PM |
