Old 09-16-2008, 09:40 AM
l u k e's Avatar
l u k e is on a distinguished road
Please Explain The Haas Control.
I see Ebay listings for Haas mills with 32 bit controls and Fanuc, what are the diffrences? I've tried getting a defination for "Fanuc" but haven't come up with anything.
Yes, I'm a newb.
Old 09-16-2008, 09:52 AM
All Haas controls are 32 bit. They can operate in three modes; Haas, Yasnac or Fanuc. As far as I know when the Haas control is operating in Yasnac or Fanuc mode it is not identical to a Yasnac or Fanuc controller, it just interprets some G codes the same way. For instance in Fanuc or Haas mode G52 is used to set a local work zero but in Yasnac G52 is just any ordinary work zero like G54 etc.
Go to the Haas website, haascnc.com, and you will find a pdf of the mill and lathe manuals if you go to the site map.
Old 09-16-2008, 10:25 AM
l u k e's Avatar
Thanks.
New software for Haas control HAILINHAAS Haas Mills 16 11-06-2007 09:03 AM
Haas TM-2 control question Zeekh Haas Mills 1 03-14-2007 09:14 PM
haas servo control heartlnd Haas Mills 0 02-10-2007 06:04 PM
haas rotary control heartlnd Haas Mills 0 02-04-2007 02:46 AM
Haas TM-2 Mill Control Malish Fanuc 1 06-26-2006 09:54 PM
