| Haas machines have a SLEEP command; have a look in your manual, I cannot remember the exact code. You leave the machine powered on with air and modify your warm up program with a line that gives the SLEEP time in hours and minutes. You have to make sure you start the program at the correct time so it wakes up at the correct time.
| M95 Sleep Mode Sleep Sleep mode is essentially a long dwell (pause). Sleep mode can be used when the user wants the machine to begin warming itself up so it can be ready for use upon the operators arrival. The format of the M95 command is: M95 (hh:mm) The comment immediately following the M95 must contain the hours and minutes that the machine is to sleep for. For example, if the current time were 6 p.m. and the user wanted the machine to sleep until 6:30 a.m. the next day, the following command would be used: M95 (12:30) The line(s) following the M95 should be axis moves and spindle warm-up commands. |
| Yeah we leave our compressor on 24/7 so we have air... On that note, my next comment/question is going to sound stupid... Power consumption was the issue with me leaving it in sleep mode.. Does anyone know how much power is used while the machine is sleeping? How do I create a custom macro program that will start up the machine? |
| To answer your power consumption question; not much, I put an ammeter on a VF0 which was just sitting idle and it was drawing about 1 to 1-1/2amps which is around 500 watts. To answer your question about creating a macro to start the machine I think that would be a trick; if the machine is off then it is not running in order to process the macro.
| I had Run a Matsuura, that had a timer on it, that would trigger the shop comressor to start, and fire up the machine after a bit, then run the warm up program. I'm not sure how this was rigged up, but if you can do it on a machine like that, it could be done with a Haas.
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
#10
Here is what I wrote and use for a warm up program. No macro, but it does use an internal sub - edit as needed. % O89998 (TM1 TABLE WARMUP) G110 G17 G40 G80 G90 (SET G110 AT CENTER OF XY TRAVELS) T10 M6 (REMOVE TOOL FOR WARM UP CLEARANCE -USE H50 TLO) M99 P101 (SPINDLE AND TABLE WARMUP) M99 P102 (SPINDLE WARMUP ONLY) (SLEEP MODE DWELL) M95 (14:00) (14 HR SLEEP 5 PM TIL 7 AM) M99 P100 M95 (13:00) (13 HR SLEEP 6 PM TIL 7 AM) M99 P100 M95 (12:00) (12 HR SLEEP 7 PM TIL 7 AM) M99 P100 M95 (11:00) (11 HR SLEEP 8 PM TIL 7 AM) M99 P100 M95 (10:00) (10 HR SLEEP 9 PM TIL 7 AM) M99 P100 M95 (09:00) (9 HR SLEEP 10 PM TIL 7 AM) M99 P100 M95 (08:00) (8 HR SLEEP 11 PM TIL 7 AM) M99 P100 M95 (07:00) (7 HR SLEEP 12 AM TIL 7 AM) M99 P100 M95 (06:00) (6 HR SLEEP 1 AM TIL 7 AM) M99 P100 M95 (05:00) (5 HR SLEEP 2 AM TIL 7 AM) M99 P100 M95 (15:00) (15 HR SLEEP) M99 P100 M95 (16:00) (16 HR SLEEP) M99 P100 M95 (17:00) (17 HR SLEEP) M99 P100 M95 (18:00) (18 HR SLEEP) M99 P100 M95 (19:00) (19 HR SLEEP) M99 P100 M95 (20:00) (20 HR SLEEP) M99 P100 M95 (21:00) (21 HR SLEEP) M99 P100 M95 (22:00) (22 HR SLEEP) M99 P100 M95 (23:00) (23 HR SLEEP) M99 P100 M95 (24:00) (24 HR SLEEP) M99 P100 M95 (25:00) (25 HR SLEEP) M99 P100 M95 (00:01) (1 MIN TEST SLEEP) M99 P100 N101 G40 G80 G90 (SPINDLE AND TABLE WARMUP) G110 T10 M6 (REMOVE TOOL FOR WARM UP CLEARANCE) G1 G43 X0.0 Y-4.0 Z4.0 H50 F100. S100 G4 P2.5 (***********GOOD LOC TO GREASE MACHINE**********) M3 (**REMOVE CHIP PANEL & VISE HANDLES********) M97 P501 L5 S200 F150. M97 P501 L4 S800 F200. M97 P501 L4 S1500 F200. M97 P501 L4 S2000 F200. M99 P103 (CONTINUE SPINDLE WARMUP) N102 G40 G80 G90 (SPINDLE WARMUP ONLY) G110 T10 M6 (REMOVE TOOL FOR WARM UP CLEARANCE) G1 G43 X0.0 Y0.0 Z4.0 H50 F100. (EDIT FOR XY TRAVELS) S200 M3 G4 P100. S800 G4 P100. S1500 G4 P100. S2000 G4 P100. N103 G40 G80 G90 (CONTINUE SPINDLE WARMUP) G110 T10 M6 (REMOVE TOOL FOR WARM UP CLEARANCE) G1 G43 X0.0 Y0.0 Z4.0 H50 F80. (EDIT FOR XY TRAVELS) S2500 M3 G4 P100. S3500 G4 P100. S4000 G4 P100. S5000 G4 P100. S5500 G4 P100. S6000 G4 P100. S2000 G4 P100. S50 M99 P100 (GO TO END OF PROGRAM) N501 M97 P602 (EDIT SUB NUMBER AS NEEDED 602 THRU 605) M99 N602 (TM1 TABLE WARMUP START X- Y+) (MOVE DOWN RIGHT Y MINUS) G1 X-14.99 Y4.99 Z4.49 G1 X10. Y2. Z-3. G1 X14.99 Y-4.99 Z-11. (EDIT AS NECESSARY CLEARS VISE HANDLE) G1 X10. Y2. Z-3. G1 X-14.99 Y4.99 Z4.49 M99 N603 (TM1 TABLE WARMUP START X- Y-) (MOVE DOWN RIGHT Y +) G1 X-14.99 Y-4.99 Z4.49 G1 X10. Y2. Z-3. G1 X14.99 Y4.99 Z-11. (EDIT AS NECESSARY CLEARS VISE HANDLE) G1 X10. Y2. Z-3. G1 X-14.99 Y-4.99 Z4.49 M99 N604 (TM1 TABLE WARMUP START X+ Y+) (MOVE DOWN LEFT Y -) G1 X14.99 Y4.99 Z4.49 G1 X-10. Y-2. Z-3. G1 X-14.99 Y-4.99 Z-11. (EDIT AS NECESSARY CLEARS VISE HANDLE) G1 X-10. Y-2. Z-3. G1 X14.99 Y4.99 Z4.49 M99 N605 (TM1 TABLE WARMUP START X+ Y-) (MOVE DOWN LEFT Y +) G1 X14.99 Y-4.99 Z4.49 G1 X-10. Y-2. Z-3. G1 X-14.99 Y4.99 Z-11. (EDIT AS NECESSARY CLEARS VISE HANDLE) G1 X-10. Y-2. Z-3. G1 X14.99 Y-4.99 Z4.49 M99 () () () () () N100 (**TABLE IS CENTERED AND SPINDLE IS WARMED UP**) (**************WARM UP IS COMPLETE***********) (******** ARE MACHINES GREASED ***********) M5 % |
| Sample prog? | Edster | Okuma | 11 | 09-25-2008 01:52 PM |
| New Router, I use solidworks, which CAM prog?? | srmaietta | General CNC (Mill and Lathe) Control Software (NC) | 3 | 02-13-2007 06:16 PM |
| fANUC AUTO POWER OFF | BIRDTOOL | General Metal Working Machines | 0 | 02-12-2007 05:43 PM |
| Alarm 913 prog: Fanuc 6T | mrvirtue | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 10-30-2006 04:14 PM |
| Need Prog. Manual For Boss 5! | MrHorsepower | Bridgeport and Hardinge Mills | 6 | 07-23-2005 07:14 PM |
