Old 09-10-2008, 06:22 AM
TOMF561 is on a distinguished road
HAAS PROGRAM BACKUP ?
I am looking for help in transfering my programs in my HAAS machine from the machine to a computer as a backup. I can transfer them 1 at a time using the SEND RS232 but with 300+ it will take some time.
My HFO suggested that I use the advanced editor.
Edit - F1 - I/O - SEND RS232 - (SELECT PGMS) - WRITE
This seems to work at the control but the problem is at the PC. Everything is received as one big file. I will have to cut & paste each program. I would be better off sending each one by itself.
I do not have floppy drives or USB on this older machine.
I have Windows XP pro as the operating system.
Any ideas?
Old 09-10-2008, 12:52 PM
JWK42 is on a distinguished road
Split ALL into separate files
I have a program written in Visual-Basic that takes your "ALL" file and splits it into separate files and save them to your hard drive with a "Long Name" if your customer and drawing number are embedded in your program text.
If you would post an example of your first 2-3 lines of your programs I can make sure it will work and then Zip it into a folder and either post here or send it to you by E-mail
Old 09-11-2008, 05:19 AM
HAAS PROGRAM TRANSFER SAMPLE
Here is a sample of one of the program beginnings.
O5210 (D-60420-2)
(KNIFE SLIDE TOP)
(12/06/2001)
(OPERATION 50)
(SET UP AND BOLT TO FIXTURE)
(T1 = CENTER DRILL)
(T2 = 5/16" DRILL)
(T3 = 3" ISCAR MILL)
(T4 = 1" HSS END MILL 2" FLUTE)
(T5 = 30 DEG. DOVETAIL CUTTER)
N3 M98 P9998
T3 M06 (3" ISCAR MILL)
G00 G43 H03 G54 G90 X-1. Y-0.5 Z3.
S2500 M03
M08
All programs also end with:
M30
My email is 0609@uticamill.com for this.
Thanks.
Thank you
Example CNC machine Setup Sheet + program backup lug_wrench Machine Problems, Solutions , Wireless DNC, serial port 4 10-14-2008 08:24 AM
Trying to load program using Cimco into a Haas Robert Timby Haas Mills 8 01-18-2008 01:21 PM
backup program of T1 and M1 to PC vpkurt Mazak, Mitsubishi, Mazatrol 4 02-08-2007 01:15 AM
TL1 Haas intuitive program restarts? elaganis Haas Mills 4 02-02-2007 02:06 PM
haas program question cncsdr Haas Mills 20 09-17-2005 12:17 AM
