Old 10-12-2004, 12:58 AM
cncsdr is on a distinguished road
Cool haas lettering
On newer haas mills I know you can type in a message and the machine will cut it in the material. can someone tell me where this option is and how to use it.
Old 10-12-2004, 08:57 AM
Rekd's Avatar
Rekd is on a distinguished road
That's a canned cycle. (Like a drill cycle). I set up my post processor for Mastercam so I can do either serial engraving or standard letter engraving using a drilling cycle. The commands for HAAS is G47. Does not work in incremental.
E = Plunge Rate
F = Feed
I = Angle of Rotation
J = Scale
P = 1 for serial
P = 0 for literal
R = Return Plane
The initial serial number can be set manually in macro variable #599.
Enjoy.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 10-12-2004, 03:07 PM
wjbzone's Avatar
wjbzone is on a distinguished road
Matt,
I think you can use incremental movements in your Gcode to position the tool prior to using the G47. You just don't know where the tool will be when the line of text is done.
Also, if you are using a rotation in the line of text, be sure to check Setting 73 on the Haas. (incremental or absolute angle)
Bill
Old 10-12-2004, 03:54 PM
Rekd's Avatar
Bill, I'm not sure if it automatically switches to absolute, but it says in the manual that G47 must be run in absolute.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Haas Lathe Reccomendations imwllc Haas Mills 12 02-24-2006 11:18 PM
Recommendation for HAAS jbo Haas Mills 10 09-19-2005 08:30 AM
HAAS mini lathe marto74 Haas Lathes 4 01-15-2004 12:55 PM
Searching Backwards jonbanquer Fadal 11 07-28-2003 07:53 PM
HAAS Indexer Prodramming / Control CAMmando Haas Mills 8 06-10-2003 11:22 AM
