Old 08-28-2008, 11:12 AM
yz426four is on a distinguished road
hass / mastercam newbie
I need help, I'm new at this, does anyone have a machinery definition file for
a Haas VF-2 for MasterCAM X software, the default file is for a Fanuc control,
or a Post file that more closely matches the Haas control? I am getting parts
out, but the work offset comes out fixed at X10. Y10. Z10., I want it to use
the G54 offset in the machine, also some NC programs include A0. and the
machine does not have an A axis enabled. Any help would be greatly appreciated. send info to dean@teamnovak.com, maybe I could send you some RC car stuff for your trouble. thanks dean
Old 08-28-2008, 03:52 PM
littlerob's Avatar
littlerob is on a distinguished road
How many machine definitions are in your machine type list there should be about 50 or more, I had the same problem with the A0, it turned out to be my problem there should be 3 Haas mills defined, two are together and one is alone I think (if I remember right) because of alphabetical order I think the three axis one is called Generic Haas and the other two are something else so they are not grouped together. Hope that helps, Robert
Old 08-28-2008, 05:00 PM
Thank you littlerob
I will check it out, thank you so much for the reply and the info!!! dean
Old 08-28-2008, 05:13 PM
timmydabull is on a distinguished road
haas 3 axis mmd.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 08-28-2008, 11:17 PM
littlerob's Avatar
I am by no means a pro, but my buddy is the local M.C. rep so let me know if you need any more help. Robert
Tags
definition file, haas, mastercam, post, vf-2
OneCNC & Hass l u k e Haas Mills 18 09-01-2008 07:08 PM
newbie=to MasterCam littlerobb Mastercam 1 05-28-2008 09:55 PM
Need A Quote- looking to buy USED HASS CNC mill H_U_S_S_A_M Want To Buy...Need help! 0 04-23-2008 04:46 PM
Difference Hass Sl-30 And Hl-3 imwllc Haas Mills 5 06-01-2005 03:45 PM
Newbie Question MasterCAM Mill for Router Sanghera Mastercam 3 04-28-2004 10:41 AM
