Old 08-25-2008, 04:27 PM
drunkenwhippet is on a distinguished road
Haas video pinout?
Hello everyone, I'm hoping that someone here would happen to have some documentation of the video output pinout for the controls used on HL-4's made in 97 and 98 (i have no idea how far back / forward this design went)
The company I work for has replaced the displays a couple of times on each of the machines we have, and the boss would rather buy a cheap display and modify it rather than spend the $400+ for the new displays from haas. I know that the video is sent over a DB-9 connector, with 5 pins actually there I'm guessing that this connector has V and H clocks and then an analog luminance (hope this is the correct term) and maybe an enable signal?
also handy would be any info on the voltage the video signal is carried on, I may have to use an op-amp or something to match the gains of the signals. I would have dove in with the oscilloscope, but mine was killed in a flood so im left without for now.
Thanks for any help you guys can give!
Jim Coleman
Old 08-25-2008, 08:54 PM
gar gar is offline
gar is on a distinguished road
080825-2053 EST USA
It is probably equivalent to an EGA (not VGA) monitor.
Need Help!- pinout for litton encoders WILSONTA Want To Buy...Need help! 1 06-28-2009 11:59 AM
HAAS TM-1P Operation Video HelicopterJohn Videos 17 02-09-2009 08:51 PM
#23-305-DS8A Pinout Richie800 Hobbycnc (Products) 2 11-15-2007 02:11 PM
DB9 pinout cabling miguisu Machine Problems, Solutions , Wireless DNC, serial port 0 05-23-2007 06:21 AM
DB9 pinout diagram standard? nervis1 General Electronics Discussion 12 12-21-2005 11:52 AM
